MHB Josh Mcdaniel's question at Yahoo Answers regarding a volume of revolution
  • Thread starter Thread starter MarkFL
    Revolution Volume
The discussion focuses on calculating the volume of a solid generated by revolving the region bounded by the x-axis, the curve y=3x^4, and the lines x=-1 and x=1 about the x-axis. The volume is determined using both the disk and shell methods, with both approaches yielding a final volume of 2π. The disk method simplifies the calculation by focusing on the first quadrant and doubling the result, while the shell method involves integrating with respect to y. Key calculations include the use of the Fundamental Theorem of Calculus (FTOC) for both methods. Ultimately, the volume of the solid of revolution is confirmed to be 2π.
MarkFL
MHB
Here is the question:
Revolving a region about the x-axis and finding the volume?
Find the volume of the solid generated by revolving the region bounded by the x axis, the curve y=3x^4 and lines x=-1 and x=1 about the x axis.
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Josh Mcdaniel,
Because the region to be revolved is symmetric across the $y$-axis, we need only consider the first quadrant part of the region, and then double the result.
Disk method:
The volume of an arbitrary disk is:
$$dV=\pi r^2\,dx$$
where:
$$r=y=3x^4$$
Hence, we have:
$$dV=\pi \left(3x^4 \right)^2\,dx=9\pi x^8\,dx$$
Summing up the disks, we find:
$$V=2\cdot9\pi\int_0^1 x^8\,dx$$
Applying the FTOC, we obtain:
$$V=2\pi\left[x^9 \right]_0^1=2\pi\left(1^9-0^9 \right)=2\pi$$
Shell method:
The volume of an arbitrary shell is:
$$dV=2\pi rh\,dy$$
where:
$$r=y$$
$$h=1-x=1-\left(\frac{y}{3} \right)^{\frac{1}{4}}$$
Hence, we find:
$$dV=2\pi y\left(1-\left(\frac{y}{3} \right)^{\frac{1}{4}} \right)\,dy=2\pi\left(y-\frac{1}{\sqrt[4]{3}}y^{\frac{5}{4}} \right)\,dy$$
And so, summing all the shells, we find:
$$V=2\cdot2\pi\int_0^3 y-\frac{1}{\sqrt[4]{3}}y^{\frac{5}{4}}\,dy$$
Application of the FTOC yields:
$$V=4\pi\left[\frac{1}{2}y^2-\frac{4}{3^{\frac{9}{4}}}y^{\frac{9}{4}} \right]_0^3=4\pi\left(\left(\frac{9}{2}-4 \right)-0 \right)=4\pi\cdot\frac{1}{2}=2\pi$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
