MHB Juan's question at Yahoo Answers regarding related rates
  • Thread starter Thread starter MarkFL
    Related rates
The area of a rectangle is increasing due to the rates of change in its length and width. Given that the length is increasing at 9 cm/s and the width at 5 cm/s, the area can be calculated using the formula A = lw. By differentiating A with respect to time and substituting the given dimensions and rates, it is determined that the area is increasing at a rate of 178 cm²/s when the length is 14 cm and the width is 12 cm. This calculation illustrates the application of related rates in geometry.
MarkFL
MHB
Here is the question:
The length of a rectangle is increasing at a rate of 9 cm/s and its width is increasing at a rate of 5 cm/s...?
The length of a rectangle is increasing at a rate of 9 cm/s and its width is increasing at a rate of 5 cm/s. When the length is 14 cm and the width is 12 cm, how fast is the area of the rectangle increasing?
Using a=lw, we have
(dA/dt) = l * (___?___) + (___?___) * (dl/dt)___3.9, 2
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: Juan's question at Yahoo! Answers regarding releated rates
Hello Juan,
The area of the rectangle is:
$$A=\ell w$$
Implicitly differentiating with respect to time $t$, we find:
$$\frac{dA}{dt}=\ell\frac{dw}{dt}+\frac{d\ell}{dt}w$$
Using the given data:
$$\ell= 14\text{ cm},\,w= 12\text{ cm},\,\frac{d\ell}{dt}= 9\frac{\text{cm}}{\text{s}},\,\frac{dw}{dt}= 5\frac{\text{cm}}{\text{s}}$$
we obtain:
$$\frac{dA}{dt}=\left(14\text{ cm} \right)\left(5\frac{\text{cm}}{\text{s}} \right)+\left(9\frac{\text{cm}}{\text{s}} \right)\left(12\text{ cm} \right)=178\frac{\text{cm}^2}{\text{s}}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
