Jumbled up spectra of stars/glaxies
  • Thread starter terahertz
  • Tags
    Spectra
In summary, astronomers are able to make sense of the jumbled-up spectrum from stars and galaxies by identifying the dominant elements present and using their unique spectral lines to determine the redshift and adjust the entire spectrum accordingly. Doppler shift does not affect the fractions of wavelengths and the distinctiveness of spectral lines allows for accurate identification of elements, even when the spectrum is shifted.
terahertz
When you look at the emission/absorption spectrum of a single element, you can clearly see various emission/absorption lines, which are characteristic of that element. However, radiation from stars/galaxies contains spectra of many elements. How do astronomers make sense of this jumbled-up spectrum? In other words, how do they know that an absorption line, for instance, comes from this element and not that, especially since the spectra are doppler-shifted?
Astronomy news on Phys.org
Doppler-shift does not change the fractions of wavelengths. Typically a few elements are dominant in the spectrum, once you identify at least one of them (via those ratios) you know redshift and can adjust the whole spectrum. Afterwards you can look up all lines in tables.
Likes davenn
Since spectral lines of each element are unique, there is actually no room to mistake which line comes from which element. Similarly, Doppler shift doesn't pose a problem, since it always affects the whole spectrum, preserving the line patterns.
E.g.
Imagine we've determined absorption lines of elements A, B, C and D in a lab. Their lines have positions:
A = 2, 5, 9, 14
B = 4, 6, 11
C = 3, 12
D = 1, 7, 13
If you then observe a spectrum with the following lines:
2 4 5 7 8 12 13 14
There's only one way to fit the elements in there (and determine how Doppler shifted it is).
Likes terahertz
Thanks a lot for your enlightening response. Your simple example clarified a lot of things!
Related to Jumbled up spectra of stars/glaxies
1. What causes jumbled up spectra in stars and galaxies?
The jumbled up spectra in stars and galaxies are caused by a combination of factors such as the chemical composition of the object, its temperature, and the movement towards or away from the observer (known as the Doppler effect). These factors affect the absorption and emission lines in the spectrum, resulting in a jumbled appearance.
2. Can the jumbled up spectra of stars and galaxies provide any useful information?
Yes, the jumbled up spectra can provide valuable information about the chemical composition, temperature, and movement of the object. By analyzing the absorption and emission lines, scientists can determine the elements present in the object, its temperature, and whether it is moving away or towards us. This information can help us understand the formation and evolution of stars and galaxies.
3. Are there any patterns in the jumbled up spectra of stars and galaxies?
Yes, there are certain patterns in the jumbled up spectra that can help scientists identify the chemical elements present in the object. Each element has a unique pattern of absorption and emission lines, which can be used to identify its presence in the spectrum. This technique, known as spectroscopy, is widely used in astronomy to study the chemical composition of stars and galaxies.
4. How does the jumbled up spectra of stars and galaxies change over time?
The jumbled up spectra of stars and galaxies can change over time due to various factors such as the object's age, its stage in the life cycle, and any external influences. For example, as a star ages, its temperature and chemical composition may change, resulting in a different spectrum. Similarly, the spectra of galaxies can change as they interact with other galaxies or experience mergers.
5. How do scientists use the jumbled up spectra of stars and galaxies to study the universe?
Scientists use the jumbled up spectra of stars and galaxies to study the universe in various ways. They can determine the composition and temperature of objects, identify their movement and evolution, and even study the history of the universe. By analyzing the spectra of different objects, scientists can also gain insights into the processes that shape our universe, such as the formation of stars and galaxies.
  • Astronomy and Astrophysics
