Jumping from a moving wagon momentum problem -- find Buffy's weight
In summary, when discussing weight, it is important to note that in physics, the gram and kilogram are units of mass while weight is associated with the force of gravity. The unit of force in the SI system is the Newton. In the given scenario, Buffy's weight cannot be determined as it is not provided in the problem.
Jujubee37
Buffy is rolling along in her 11.8 kg wagon at 3.8 m/s (in the positive direction) when she jumps off the back. She continues to move forward at 1.8 m/s relative to the ground. This causes her wagon to go speeding forward at 8.87 m/s relative to the ground. How much does Buffy weigh?
n/a
I have attempted to plug in grams, kiliograms, and even pounds but it was wrong.
In everyday life, we often see "weight" given in grams or kilograms. However, in physics, the gram and the kilogram are units of mass while weight is associated with the force of gravity. What is the unit of force in the SI system?
Likes Lnewqban, berkeman and Jujubee37
Jujubee37 said:
Homework Statement:: Buffy is rolling along in her 11.8 kg wagon at 3.8 m/s (in the positive direction) when she jumps off the back. She continues to move forward at 1.8 m/s relative to the ground. This causes her wagon to go speeding forward at 8.87 m/s relative to the ground. How much does Buffy weigh?
Relevant Equations:: n/a
Attempted to plug in into what? We do not know what formula or even concept you are trying to use. As such it is impossible to pinpoint where you are going wrong.
FAQ: Jumping from a moving wagon momentum problem -- find Buffy's weight
What is the definition of momentum?
Momentum is a measure of an object's motion, calculated as the product of its mass and velocity.
How does momentum relate to jumping from a moving wagon?
In the context of jumping from a moving wagon, momentum is important because it determines the amount of force needed to stop or change the direction of the person's motion.
What is the equation for calculating momentum?
The equation for momentum is p = mv, where p is momentum, m is mass, and v is velocity.
How can I find Buffy's weight using the momentum equation?
To find Buffy's weight, you would need to know her mass and velocity at the time of the jump. Then, you can plug those values into the momentum equation and solve for her weight.
Is there a specific unit for momentum?
Yes, momentum is typically measured in kilogram-meters per second (kg*m/s) in the metric system and in slug-feet per second (slug*ft/s) in the imperial system.
