Junkyard sized Large electromagnet
In summary, the conversation discusses the use of a portable generator and step up transformer to create a scrap yard size electromagnet. There is also mention of a semi truck rim with a solid core axle being used and access to unlimited amounts of wire to be used in the project. The conversation ends with questions about the best way to place the windings and the size of wire to use for the windings. The thread is closed due to the need for expert guidance in dealing with high voltages and currents.
midknight
what we have to work with is a portable generator ~240vac ~3500watts then to a step up transformer so output ~540vac. then a full wave bridge rectifier to make the DC
thought is we have a semi truck rim (will get the diameter/size soon) (due to this will get slammed around and banged into other scrap yard items) with a ~3.5"solid core axle welded into the center.
we have access to unlimited amount of thhn* wire of pretty much any awg (solid or stranded) to use in this project we would like to create a scrap yard size electromagnet
extra equipment can be implemented in this project suggested. (bigger than a rim if needed)
questions are:
1) best way to place the windings or just wrap the center pole?
2) best size wire to use for the windings to make enough induction resistance so the generator will last a lil while
will post pictures and more pictures and more pictures of the build and progress and end results so everyone can see how it works when completed so others can build one if they would like or use as a reference for their own projects.
I'm sorry, but we cannot help you with this question. You will be dealing with voltages and currents high enough that anonymous guidance from an anonymous internet forum about how to design your field coils isn't going to be good enough - you need input from people who have actually done it before, who are familiar with the specifics of your project.
So this thread is closed. (Somewhat regretfully, because it is a fascinating project).
Related to Junkyard sized Large electromagnet
1. What is a junkyard sized large electromagnet?
A junkyard sized large electromagnet is a powerful electromagnet that is typically used in junkyards to lift and move heavy metal objects, such as cars, forklifts, and other large machinery.
2. How does a junkyard sized large electromagnet work?
A junkyard sized large electromagnet works by using electricity to create a magnetic field. The magnetic field attracts and lifts metal objects, allowing them to be moved or manipulated.
3. What are the benefits of using a junkyard sized large electromagnet?
The main benefit of using a junkyard sized large electromagnet is its strength and efficiency. It can lift and move extremely heavy objects with ease, making it a valuable tool in junkyards and other industrial settings.
4. Are there any safety considerations when using a junkyard sized large electromagnet?
Yes, there are important safety considerations when using a junkyard sized large electromagnet. It is important to follow proper safety protocols, such as wearing protective gear and ensuring that the magnet is turned off when not in use, to prevent accidents and injuries.
5. Can a junkyard sized large electromagnet be used for other purposes?
Yes, a junkyard sized large electromagnet can be used for a variety of purposes beyond just lifting and moving heavy objects. It can also be used in industries such as mining, recycling, and manufacturing for tasks such as separating metals or removing metal debris from materials.
  • Electrical Engineering
9K
  • General Engineering
9K
