B Just for fun: Cubic Graph Plot
Desmos.com is highlighted as an effective online graphing tool for experimenting with the Newton-Raphson method, particularly in solving cubic equations. The discussion emphasizes the importance of accurately calculating x-intercepts and turning points on cubic graphs, suggesting that additional iterations may improve precision. A specific example is provided for finding square roots using the positive x-intercept of the function f(x)=x^2-a, with a comparison to a more accurate numeric value. Users are encouraged to explore the provided links for practical applications of these concepts. Overall, the thread showcases the utility of Desmos for mathematical experimentation and visualization.
neilparker62
Insights Author
TL;DR Summary
Cubic Graph plot on Desmos
Desmos.com is a great online graphing utility which I'm sure is familiar to many PF users. I wanted to experiment with the Newton-Raphson method using it so chose solution of cubic graphs as an example. The graph shows a variable cubic on which all turning points and intercepts are calculated and shown. x-intercepts by Newton-Raphson.
I'm sure readers will find parameter values where the x-intercepts are not that accurate - in that case add a couple more "g(g(.." iterations!
https://www.desmos.com/calculator/lejtdd8fws
Likes BvU and jim mcnamara
Mathematics news on Phys.org
Here's another use of Newton-Raphson whereby the square root of a number is determined by finding the positive x-intercept of ##f(x)=x^2-a##. The intercept is marked on the graph but the side panel shows a more accurate numeric value of the root against parameter d where ##d=\sqrt{a}##. The start value for determination of the square root is the square root of the nearest square greater than a.
https://www.desmos.com/calculator/qbyev8tuqz
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
