Just how important is exercise to academic success?
In summary, there is a correlation between academic success and more exercise, especially with kids. However, there is no causation that exercising will help your grades somehow. Exercise is good to get your mind off academic things so that when you exercise after some time of studying and then start studying again, it will feel as if you haven't studied in a while and will be more focused on the task at hand. Exercising also releases endorphins that contribute to overall well-being and may make studying easier. However, personal anecdotes suggest that intense exercise may be counterproductive for some individuals and it is important to find a balance between exercise and studying. Ultimately, there is a correlation between exercise and improved brain function, but there are limits and individuals may
-Dragoon-
309
When reading tips on various websites of how to "study physics" I always see they bring up exercise as being one of the key things to success. But, is it really that integral to one's success? I'm quite skinny and frail, and I've noticed most of my professors and other classmates aren't in shape either (they are skinny and frail or on the larger side). Would like to hear some input.
There is a correlation between academic success and more exercise, especially with kids. However, there is no causation that exercising will help your grades somehow. Exercise is good to get your mind off academic things so that when you exercise after some time of studying and then start studying again, it will feel as if you haven't studied in a while and will be more focused on the task at hand.
Correlation doesn't imply causation :-p
I think that people who are workaholics in academics also have the work ethic to work hard in the weight room. They might have that natural drive to just work hard. Exercise does make you feel better and think more clearly though, from my personal experience (especially if you have been doing it for a while).
Doing compound lifting movements like heavy squats, bench press and pull ups has been shown to slightly raise testosterone which has also been shown to aid in spatial processing and other mental functions. Endorphins released by exercise also contribute to an overall sense of well-being, which may make studying easier. These are things you have to adapt to though, be consistent with it.
I have to disagree with this. I used to train heavy compound movements while on a strict healthy diet, daily running... the whole nine yards for 3 years. This was manageable until the year I took up a full courseload (2nd year undergrad physics) and the only way I managed to survive was by giving up on exercise completely. Intense exercise made me look good alright, but I felt lethargic for most of the day and simply could not concentrate for the solid lengths of time I needed to get through 1 problem at all. So I had to trade my discipline in exercise for some academic discipline. You can't have everything in life. Ymmv.
I don't think it's required but when I work out consistently I am less tired and more productive.
Also, consider the following flow chart.
Exercise -> fit -> girls -> confidence -> grades
How do the first four steps help you get through a solid hard problem sheet?
Well, I know when I am more confident I perform better academically.
It's simply personal anecdote, but I feel much better when I get regular exercise. It may take about an hour out of my day that I could be otherwise studying, but it adds to my productivity. I am less tired, I can get more done in less time, and I don't sleep over 7 hours.
Same here. Plus, it's physically difficult for me to sit for hours at a time, as was often required in order to get my work done. It's a lot easier if I'm fit, though. When I wasn't fit, I'd really feel it in my back after a couple days of long study sessions.
I'm feeling it right now, really badly.
But I'm forcing myself to stretch vigorously every couple of minutes and at least get some pushups in most mornings to not go completely limp.
I think girls and grades are rather anti-correlated from what I've seen with people :P
One could assume he forgot a step:
Exercise-> fit -> girls -> girlfriend that helps with homework -> grades
From what I've read, there is quite a bit of evidence that suggests a positive correlation between exercise (primarily cardiovascular, but I believe also strength exerise as well) and exectutive function (setting goals, establishing problem-sovling strategies, ignoring distractions, etc.)
The CBC's "Quirks and Quarks" also did an episode not too long ago that mentioned a correlation between memory and exercise - I believe it was in an Alzheimer's context.
I suspect that this is one of those generalizations where on average a population that exercises more will perform better on a battery of tests. But there are likely limits. Eventually, you get to the point where running twenty km per day instead of ten isn't going to give you any additional cognitive benefit, but will cut into your study or creative time.
there is no causation that exercising will help your grades somehow.http://www.infoocean.info/avatar1.jpg
Except that, there is:
http://journals.lww.com/acsm-essr/A...e_Enhances_and_Protects_Brain_Function.6.aspx
Tons and tons of peer reviewed papers showing that exercise improves brain function and memory. I think we can all agree that there IS a correlation between brain function/memory and grades.
Like stated above however, I am sure that eventually you would reach a point where any additional benefit is negligible.
Interesting feedback. I usually study for 4 hours a day, but find myself a bit distracted sometimes and I probably get somewhere between 2-3 hours of efficient studying done. I've read a few studies, but they all seem to deal with young children. I have yet to read a study done on professional adults that shows exercise improves their performance on the job.
My experience is similar to lavabug's one. Less than a month ago I stopped to go to gym (been there for 1.5 year, increased my mass by about 10 kg) and running about 5 to 6km 3 times per week and I didn't notice any improvement in my grades nor did I felt more comfortable with solving physics problems, etc. when I was exercising a lot vs 0 sport/physical effort. For the most part it took out time of my studies and would get my brain tired. When in the gym my mind was totally focused on physics stuff like where to place the iron bar so that it doesn't fall, how many Newton I was lifting, what was my power output for such and such exercise, where to place my water bottle so that it doesn't warm quickly due to air convection of the several fans, music and lights, etc. If that's what one would call "getting
as the post #2 of this thread asserts, then I wonder what are the academia things he has in mind.
Funnily I started gym and running by reading a thread in this very forum section (Academic Guidance) and bought the idea of refreshed mind+benefits on physics studies. Well, it didn't harmed my academic performance, but didn't increase it either. My mind wasn't refreshed but more tired, of this I'm sure.
If I had more time -okay maybe money too-, I'd probably go back to gym+run though.
I've run at least 2 miles a day every weekday since high school, I think being fit and healthy is important.
However, the guy I shared an office with in grad school was easily 50 or 60 lbs over weight and had quite literally never exercised a day in his life. We worked for the same advisor, published roughly the same amount in graduate school, etc. These are just anecdotes, but its the only data I have on the subject.
Related to Just how important is exercise to academic success?
Question 1: How does exercise affect academic performance?
Numerous studies have shown that regular exercise can have a positive impact on academic performance. Exercise can improve cognitive functions such as memory, attention, and information processing, which are all crucial for academic success. Additionally, exercise can also decrease stress, anxiety, and depression, which can hinder academic performance.
Question 2: How often should I exercise to see improvements in academic performance?
The American Heart Association recommends at least 60 minutes of moderate to vigorous physical activity per day for children and adolescents, and at least 150 minutes of moderate exercise or 75 minutes of vigorous exercise per week for adults. However, even small amounts of exercise can have a positive impact on academic success, so any amount of physical activity is beneficial.
Question 3: Can exercise help with focus and concentration during studying?
Yes, exercise has been shown to improve focus and concentration. When we exercise, our brain releases chemicals such as dopamine and serotonin, which can improve our mood and attention. This can help us stay focused and engaged while studying, leading to better retention of information.
Question 4: Are there specific types of exercises that are more beneficial for academic success?
While any type of physical activity can be beneficial, aerobic exercises, such as running, swimming, or cycling, have been shown to have the most positive impact on cognitive functions and academic performance. These types of exercises increase blood flow and oxygen to the brain, which can improve brain function.
Question 5: How does exercise impact overall well-being and academic success?
Regular exercise has been linked to improved overall well-being, including physical, mental, and emotional health. When we feel healthy and happy, we are more likely to be motivated and focused, which can have a direct impact on academic success. Additionally, exercise can also improve sleep quality, which is crucial for academic performance.
  • STEM Academic Advising
9K
