Just need an answer checked on a problem
  • Thread starter AryRezvani
In summary, the conversation is about a spherical navigation buoy that is tethered to the sea floor by a vertical cable. The buoy has an outside diameter of 1.00 m and is made of an aluminum shell and solid plastic, with densities of 2700 kg/m3 and 200 kg/m3, respectively. The buoy is set to float one-third out of the water and the task is to determine the tension in the cable. The conversation also includes equations and calculations related to the buoy's volume, buoyant force, weight, and the tension in the cable. Finally, there is a question about the buoy's position in the water that needs clarification.
AryRezvani
67
I'd like to mention beforehand this is not my work, I'm simply just trying to understand it.
I believe the answer is incorrect, could someone kindly indicate why?
A spherical navigation buoy is tethered to the sea floor by a vertical cable as
shown in the following figure. The outside diameter of the buoy is 1.00 m. The
interior of the buoy consists of an aluminum shell 1.0 cm thick, and the rest is
solid plastic. The density of aluminum is 2700 kg/m3 and the density of the plastic
is 200 kg/m3. The buoy is set to float exactly one-third out of the water.
Determine the tension in the cable.
Both work and equations are below.
Buoy Quiz
1) The density of water is 1 Ton / Cubic Meter or 1000 Kg / Cubic Meter.
2) The law of buoyancy is Volume of object submerged is equal to Volume of liquid displaced. Now, calculate the volume of hemisphere.
V = (4/6) x Pi x (R^3) , where R = 1/2 of Diameter = 0.50m
Pi = 3.1416
V = 0.262 cu.meter
Calculate the volume of aluminium shell :
V(Al) = (0.01) x 2 x Pi x R^2
V(Al) = 0.016 cu.meter
Therefore, the volume of plastic is :
V(Plastic) = Vol. of hemisphere - Vol. of aluminium
V(Plastic) = (0.262 - 0.016) = 0.246 cu.meter
The Buoyant Force is :
Bf = Volume of Hemisphere x Density of Water
= (0.262 m^3) x (1000 Kg/m^3)
Bf = 262 Kgs.
The Weight of Object is :
W = Volume of Sphere x Density of Materials
W = ((0.016 m^3) x (2700 Kg/m^3) x 2) + ((0.246 m^3) x (200 Kg/m^3) x 2)
W = 184.80 Kgs.
The Tension (T) in the Cable is:
T = Bf - W
T = 262 kgs. - 184.80 Kgs.
T = 77.20 Kgs.
Buoy Quiz
Pi = 3.1416
V = 0.262 cu.meter
Bf = 262 Kgs.
W = 184.80 Kgs.
T = Bf - W
T = 77.20 Kgs.
Is this buoy supposed to be floating 1/3 out of the water or 1/2 out of the water [see red above]
FAQ: Just need an answer checked on a problem
What is the problem that needs to be checked?
The problem that needs to be checked is not specified, so it is difficult to give an answer. It could be a math problem, a coding problem, or a scientific problem. Please provide more information for a specific answer.
Can you provide more context on the problem?
Yes, I can provide more context on the problem if you provide more details. What is the subject of the problem? What information do you already have? Is there a specific question that you need help with?
Can you explain the steps to solve the problem?
Yes, I can explain the steps to solve the problem if you provide the problem itself. Without the problem, it is difficult to give a specific answer. However, in general, the steps to solve a problem involve understanding the question, gathering necessary information, and using appropriate methods or tools to find the solution.
Is there a specific answer you are looking for?
Yes, there may be a specific answer you are looking for, but without the problem or more context, it is difficult to determine the correct answer. It is important to provide as much information as possible so that the answer can be tailored to your specific problem.
Can you check my answer to see if it is correct?
Yes, I can check your answer to see if it is correct, but again, without the problem or more context, it is difficult to determine if your answer is correct. It is important to provide the problem and any necessary information so that I can accurately check your answer.
