MHB JustCurious's question at Yahoo Answers (Diagonalization)
  • Thread starter Thread starter Fernando Revilla
    Diagonalization
The discussion focuses on the diagonalization of matrices with mutually orthogonal eigenvectors, specifically addressing the matrix A represented as A = UDU^-1, where D is diagonal and U consists of the eigenvectors. The key suggestion is to replace U^-1 with U^T, which is valid for orthogonal matrices, and then take the transpose of both sides. This leads to the conclusion that A is equal to its transpose, demonstrating that A is symmetric. The properties of transposition and orthogonality are crucial in this proof. The discussion emphasizes the relationship between diagonalization and symmetry in matrices.
Fernando Revilla
MHB
Here is the question:
his problem is about diagonalization of matrices A which have n mutually orthogonal eigenvectors, each of which has length one. It is customary to write U for the matrix with columns constructed from the eigenvectors. The problem is straightforward, but requires you to follow a given suggestion. Here is the problem, followed by the suggestion.
Suppose A = UDU^-1;
where D is diagonal and U is given as above. The entries of D; U are real numbers. Show that A is equal to its transpose matrix.
Suggestion: In the diagonalization formula for A, replace U^-1 by U^T (this is valid for such matrices) and then take the transpose of both sides. Compare.
In the literature, A is called symmetric, and U is called orthogonal.
Here is a link to the question:
Diagnalization with matrices? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello JustCurious,
We have $U^{-1}=U^T$, hence $A=UDU^T$. Then, using well kown properties of transposition $$A^T=(UDU^T)^T=(U^T)^TD^TU^T=UDU^T=A$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
