Justification for cancellation in rational functions
In summary: This is justified because the limit only looks at the behavior of the function as we approach the point, not what happens exactly at the point. Therefore, we can cancel the x's in the original function and still have the same limit, even though the new function may not be defined at the point where we canceled the x's.
Mr Davis 97
1,462
44
For example, say we have ##\frac{x^4(x - 1)}{x^2}##. The function is undefined at 0, but if we cancel the x's, we get a new function that is defined at 0. So, in this case, we have ##x^2(x - 1)##, then ##x^2(x - 1)(1)##, and since ##\frac{x^2}{x^2} = 1##, we then have ##\frac{x^4(x - 1)}{x^2}##. However, this is a new function, since the domain has changed to exclude x = 0. How is this justified? Why can we go about changing the function in that way. Specifically, when we evaluate limits, in the case where we have ##\frac{x^4(x - 1)}{x^2}##, how to we know that cancelling the x's will lead to the correct limit, since that is in effect the limit of the function ##x^2(x−1)## and not ##\frac{x^4(x - 1)}{x^2}##?
Mathematics news on Phys.org
We can't in general do that and say they're the same function. However, there's a property of limits that, given a function [itex]f[/itex] and a function [itex]g[/itex] such that [itex]g(x) = f(x)[/itex] except maybe at a point [itex]x = c[/itex], then [tex]\lim_{x \to c} f(x) = \lim_{x \to c} g(x)[/tex] What we care about is the limit. We're not worried about what actually happens at the point. We're only worried about what happens as we approach the point. What's important here is that we know that the two functions are equal everywhere except that one point.
I may be able to find a specific statement of this.
The following problem comes from Chapter 5, problem 10 of Spivak's Calculus 1st edition:
Suppose there is a [itex] \delta > 0[/itex] such that [itex]f(x) = g(x)[/itex] when [itex] 0 < |x - a| < \delta[/itex]. Prove that [itex] \lim_{x \to a} f(x) = \lim_{x \to a} g(x)[/itex]. In other words, the limit only depends on the values of [itex]f(x)[/itex] for [itex]x[/itex] near [itex]a[/itex].
If you're familiar with epsilon-delta proofs (the limit approaches [itex]L[/itex] if [itex]0 < |x - a| < \delta [/itex] implies [itex] |f(x) - L| < \epsilon[/itex]), then this is easy to see: We know that [itex]f(x) = g(x)[/itex] for some neighborhood around [itex]a[/itex], that is, [itex]f(x) = g(x)[/itex] when [itex]|x - a| < \delta '[/itex]. Furthermore, if [itex]\lim_{x \to a} f(x) = L[/itex] then given an [itex]\epsilon > 0[/itex], then there exists some [itex]\delta > 0[/itex] such that [itex]0 < |x - a| < \delta \implies |f(x) - L| < \epsilon[/itex]. Now just make sure [itex]\delta ' < \delta[/itex], and then we know [itex]g(x)[/itex] is equivalent to [itex]f(x)[/itex], so we can replace it in our mathematical statement: [itex] 0 < |x - a| < \delta ' \implies |g(x) - L| < \epsilon[/itex]. Thus [itex]f[/itex] and [itex]g[/itex] both approach [itex]L[/itex] as [itex]x \to a[/itex].
Intuitively, this just means that we only care about the neighborhoods near the point we're approaching. Since the two functions are equal everywhere except that one point, the two limits are still the same.
Related to Justification for cancellation in rational functions
What is cancellation in rational functions?
Cancellation in rational functions refers to the process of simplifying a rational expression by dividing out common factors in the numerator and denominator. This is similar to reducing fractions in arithmetic.
Why is cancellation important in rational functions?
Cancellation is important because it helps us to simplify complex rational expressions and make them easier to work with. It also allows us to find and analyze the behavior of the function at certain points.
When can we cancel in rational functions?
We can only cancel common factors in rational functions if they are being multiplied or divided. We cannot cancel factors that are being added or subtracted.
What are the rules for cancellation in rational functions?
The rules for cancellation in rational functions are as follows: 1) Only common factors can be cancelled. 2) The common factors must be in the form of (x-a) or (a-x). 3) The common factors must be being multiplied or divided. 4) We cannot cancel factors being added or subtracted.
Can we always cancel in rational functions?
No, we cannot always cancel in rational functions. There may be cases where the common factors do not follow the rules for cancellation or where the factors cannot be factored further. It is important to check for any restrictions on the domain of the function before cancelling.
  • General Math
  • General Math
