Karagoz
- 52
- 5
- Homework Statement
- Implement Kalman filter to track moving object that's moving back and forth between two points
- Relevant Equations
- Covariance Extrapolation Equations, Kalman gain computations, Covarinace Update Equations
Below is the whole code. I can't change the whole code, I can only change the "Kalman class".
The Kalman class in the code below is my attempt to solve the problem.
But the code doesn't work well.
I have written these 5 equations in the Kalman-filter algorithm:
State Extrapolation Equation
Covarinace Extrapolation Equation
Kalman gain computation (computation of alpha, beta and gamma, computation of gamma is commented)
State Update Equation
Covariance Update Equation
I have just written as it's described in different guides online like KalmanFilter.net
But when I run the code it doesn't work well.
How suspect my equations are wrong. How do I correct those equations?The Kalman class is between line 71 and 129.
The whole code:
import pygame as pg
from random import random,randint
import numpy as np
from numpy.linalg import norm
fps = 0.0
class Projectile():
def __init__(self, background, kalman=None):
self.background = background
self.rect = pg.Rect((800,700),(16,16))
self.px = self.rect.x
self.py = self.rect.y
self.dx = 0.0
self.kalm = kalman
def move(self,goal):
if self.kalm:
goal = self.kalm.calc_next(goal)
deltax = np.array(float(goal) - self.px)
#print(delta2)
mag_delta = norm(deltax)#* 500.0
np.divide(deltax,mag_delta,deltax)
self.dx += deltax
#if self.dx:
#self.dx /= norm(self.dx) * 50
self.px += self.dx /50.0
self.py += -0.5
try:
self.rect.x = int(self.px)
except:
pass
try:
self.rect.y = int(self.py)
except:
pass
class Target():
def __init__(self, background, width):
self.rect = pg.Rect(self.background.get_width()//2-width//2,
50, width, 32)
self.dx = 1 if random() > 0.5 else -1
def move(self):
self.rect.x += self.dx
if self.rect.x < 300 or self.rect.x > self.background.get_width()-300:
self.dx *= -1
def noisy_x_pos(self):
pos = self.rect.x
center = self.rect.width//2
noise = np.random.normal(0,1,1)[0]
return pos + center + noise*300.0
# Here is the Kalman filter I need to develop
class Kalman():
def __init__(self):
self._dt = 1 # time step
self._pos = 785 # initialized position
self._vel = 1 #initialized velocity
self._acc = 0.05 #initialized accelaration
self._pos_est_err = 1000000 #position estimation uncertainty
self._vel_est_err = 1000000 #velocity estimation uncertainty
self._acc_est_err = 2000 #acceleratione stimation uncertainty
self._pos_mea_err = 300 #measurement error
self._vel_mea_err = 100 #velocity measurement error
self._acc_mea_err = 4 #acceleration measurement error
self._alpha = 1 # converges to 0.32819526927045667
self._beta = 1 # converges to 0.18099751242241782
self._gamma = 0.01 # gamma
self._q = 30 # process uncerrainty for position
self._q_v = 4 # process uncertainty for velocity
self._q_a = 2 # process uncertainty for acceleration
self._last_pos = 785
self._measured_velocity = 0 def calc_next(self, zi):
self._measured_velocity = zi - self._last_pos
self._last_pos = zi
#State extrapolation
self._pos = self._pos + self._vel*self._dt + 0.5*self._acc*self._dt**2
self._vel = self._vel + self._acc*self._dt
self._acc = self._acc
#Covariance extrapolation
self._pos_est_err = self._pos_est_err + self._dt**2 * self._vel_est_err + self._q
self._vel_est_err = self._vel_est_err + self._q_v
self._acc_est_err = self._acc_est_err + self._q_a
#Alhpa-beta-gamma update
self._alpha = self._pos_est_err / (self._pos_est_err + self._pos_mea_err)
self._beta = self._vel_est_err / (self._vel_est_err + self._vel_mea_err)
#self._gamma = self._acc_est_err / (self._acc_est_err + self._acc_mea_err)
#State update
pos_prev = self._pos
self._pos = pos_prev + self._alpha*(zi - pos_prev)
self._vel = self._vel + self._beta*((zi - pos_prev)/self._dt)
self._acc = self._acc + self._gamma*((zi - pos_prev) / (0.5*self._dt**2))
#Covariance update
self._pos_est_err = (1-self._alpha)*self._pos_est_err
self._vel_est_err = (1-self._beta)*self._vel_est_err
self._acc_est_err = (1-self._gamma)*self._acc_est_err
return self._pospg.init()
w,h = 1600,800
background = pg.display.set_mode((w,h))
surf = pg.surfarray.pixels3d(background)
running = True
clock = pg.time.Clock()
kalman_score = 0
reg_score = 0
iters = 0
count = 0
while running:
target = Target(background, 32)
missile = Projectile(background)
k_miss = Projectile(background,Kalman()) #kommenter inn denne linjen naar Kalman er implementert
last_x_pos = target.noisy_x_pos
noisy_draw = np.zeros((w,20))
trial = True
iters += 1
while trial:
# Setter en maksimal framerate på 300. Hvis dere vil øke denne er dette en mulig endring
clock.tick(30000)
fps = clock.get_fps()
for e in pg.event.get():
if e.type == pg.QUIT:
running = False
background.fill(0x448844)
surf[:,0:20,0] = noisy_draw
last_x_pos = target.noisy_x_pos()
# print(last_x_pos)
target.move()
missile.move(last_x_pos)
k_miss.move(last_x_pos) #kommenter inn denne linjen naar Kalman er implementert
pg.draw.rect(background, (255, 200, 0), missile.rect)
pg.draw.rect(background, (0, 200, 255), k_miss.rect) #kommenter inn denne linjen naar Kalman er implementert
pg.draw.rect(background, (255, 200, 255), target.rect)
noisy_draw[int(last_x_pos):int(last_x_pos)+20,:] = 255
noisy_draw -= 1
np.clip(noisy_draw, 0, 255, noisy_draw)
coll = missile.rect.colliderect(target.rect)
k_coll = k_miss.rect.colliderect(target.rect) #kommenter inn denne linjen naar Kalman er implementert#
if coll:
reg_score += 1
if k_coll: #kommenter inn denne linjen naar Kalman er implementert
kalman_score += 1
oob = missile.rect.y < 20
if oob or coll or k_coll: #endre denne sjekken slik at k_coll ogsaa er med naar kalman er implementert
trial = False
pg.display.flip()
print('kalman score: ', round(kalman_score/iters,2)) #kommenter inn denne linjen naar Kalman er implementert
print('regular score: ', round(reg_score/iters,2))
count += 1
print("Nr. of tries:", count)
pg.quit()
