MHB Katie's question at Yahoo Answers regarding summations
  • Thread starter Thread starter MarkFL
The discussion centers on solving two summation problems using sigma notation. The first sum involves expanding the expression (i+1)(2i+1) and applying known summation formulas, resulting in a final expression of n(4n^2 + 15n + 17)/6. The second sum, (1 + 3i)^2, is similarly expanded and simplified, yielding n(6n^2 + 15n + 11)/2. Both solutions utilize properties of sums and linearity to derive the final results. The thread provides a detailed step-by-step approach to solving these summations.
MarkFL
MHB
Here are the questions:
Find the value of the sum of a sigma notation?
n
∑ (i+1)(2i+1)
i=1
and
n
∑(1+3i)^2
i=1
Cant figure these out, could someone show me how to do them step by step?
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Katie,
One way we could find these sums is the expand the summands, and then rely on the following formulas:
(1) $$\sum_{k=1}^{n}(1)=n$$
(2) $$\sum_{k=1}^{n}(k)=\frac{n(n+1)}{2}$$
(3) $$\sum_{k=1}^{n}\left(k^2 \right)=\frac{n(n+1)(2n+1)}{6}$$
Also, we will use the following linearity properties of sums:
(4) $$\sum_{k=k_i}^{k_f}\left(a\cdot f(k) \right)=a\cdot\sum_{k=k_i}^{k_f}\left(f(k) \right)$$
(5) $$\sum_{k=k_i}^{k_f}\left(f(k)\pm g(k) \right)=\sum_{k=k_i}^{k_f}\left(f(k) \right)\pm\sum_{k=k_i}^{k_f}\left(g(k) \right)$$
Now, the first sum can be expanded as follows:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=\sum_{k=1}^{n}\left(2k^2+3k+1 \right)$$
Using (5), we may write:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=\sum_{k=1}^{n}\left(2k^2 \right)+\sum_{k=1}^{n}(3k)+\sum_{k=1}^{n}(1)$$
Using (4), we may write:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=2\sum_{k=1}^{n}\left(k^2 \right)+3\sum_{k=1}^{n}(k)+\sum_{k=1}^{n}(1)$$
Using (1)-(3), we may write:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=2\left(\frac{n(n+1)(2n+1)}{6} \right)+3\left(\frac{n(n+1)}{2} \right)+(n)$$
Combine terms:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=\frac{2n(n+1)(2n+1)+9n(n+1)+6n}{6}$$
Factor numerator:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=\frac{n\left(2(n+1)(2n+1)+9(n+1)+6 \right)}{6}$$
Expand within second factor of numerator:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=\frac{n\left(4n^2+6n+2+9n+9+6 \right)}{6}$$
Collect like terms:
$$\sum_{k=1}^{n}\left((k+1)(2k+1) \right)=\frac{n\left(4n^2+15n+17 \right)}{6}$$
Now for the second sum (and following the same steps as for the first sum):
$$\sum_{k=1}^{n}\left((3k+1)^2 \right)=9\sum_{k=1}^{n}\left(k^2 \right)+6\sum_{k=1}^{n}(k)+\sum_{k=1}^{n}(1)$$
$$\sum_{k=1}^{n}\left((3k+1)^2 \right)=9\left(\frac{n(n+1)(2n+1)}{6} \right)+6\left(\frac{n(n+1)}{2} \right)+(n)$$
$$\sum_{k=1}^{n}\left((3k+1)^2 \right)=\frac{3n(n+1)(2n+1)+6n(n+1)+2n}{2}$$
$$\sum_{k=1}^{n}\left((3k+1)^2 \right)=\frac{n\left(6n^2+9n+3+6n+6+2 \right)}{2}$$
$$\sum_{k=1}^{n}\left((3k+1)^2 \right)=\frac{n\left(6n^2+15n+11 \right)}{2}$$
Another way we could find these sums is to treat them as linear inhomogenous difference equations:
$$S_{n}-S_{n-1}=an^2+bn+c$$ where $$S_1=a+b+c$$
Now, observing that the corresponding homogeneous equation has the characteristic root $r=1$, we know the homogenous solution is:
$$h_n=c_1$$
And bearing in mind that none of the terms in the particular solution can be a solution to the homogenous equation, we then take for the particular solution the form:
$$p_n=An^3+Bn^2+Cn$$
Now we may use the method of undetermined coefficients to determing the values of the parameters $A,B,C$.
Substituting the particular solution into the difference equation, we obtain:
$$\left(An^3+Bn^2+Cn \right)-\left(A(n-1)^3+B(n-1)^2+C(n-1) \right)=an^2+bn+c$$
Expanding and collecting like terms, we get
$$3An^2+(-3A+2B)n+(A-B+C)=an^2+bn+c$$
Equating like coefficients, we obtain the linear system:
$$3A=a\implies A=\frac{a}{3}$$
$$-3A+2B=b\implies B=\frac{a+b}{2}$$
$$A-B+C=c\implies C=\frac{a+3b+6c}{6}$$
And so our particular solution is:
$$p_n=\frac{a}{3}n^3+\frac{a+b}{2}n^2+\frac{a+3b+6c}{6}n$$
Combining terms, we obtain:
$$p_n=\frac{n\left(2an^2+3(a+b)n+(a+3b+6c) \right)}{6}$$
Thus, by the principle of superposition, we find the general solution is:
$$S_n=h_n+p_n=c_1+\frac{n\left(2an^2+3(a+b)n+(a+3b+6c) \right)}{6}$$
Now, using the initial value, we may determine the parameter $c_1$:
$$S_1=c_1+\frac{2a+3(a+b)+(a+3b+6c)}{6}=a+b+c$$
$$c_1=a+b+c-\frac{6a+6b+6c}{6}=0$$
Thus, the general solution satisfying the given conditions is:
$$S_n=\frac{n\left(2an^2+3(a+b)n+(a+3b+6c) \right)}{6}$$
Now, for the first problem, we identify:
$$a=2,\,b=3,\,c=1$$
Hence:
$$S_n=\frac{n\left(4n^2+15n+17 \right)}{6}$$
And for the second problem, we identify:
$$a=9,\,b=6,\,c=1$$
Hence:
$$S_n=\frac{n\left(18n^2+45n+33 \right)}{6}=\frac{n\left(6n^2+15n+11 \right)}{2}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
