MHB Katresha Davis' Trig Questions: Distance, Altitude & Ratio
  • Thread starter Thread starter MarkFL
    Trignometry
The discussion focuses on solving trigonometric problems related to the altitudes of two helicopters. The altitude difference between the helicopters is calculated to be 2,000 feet. To find the distance along the line of sight, the sine function is utilized, relating the angle and the opposite side to the hypotenuse. The formula derived is d = 2000/sin(43 degrees), leading to a calculated distance of approximately 2,932.56 feet. The thread provides a clear method for applying trigonometric ratios to real-world scenarios.
MarkFL
MHB
Here are the questions:
Prealgebra math problems ?
The pilot of a helicopter at an altitude of 6,000 ft sees a second helicopter is 4,000 ft. What is the distance from the first helicopter to the second along the line of sight?
6. What is the difference in altitude between the two helicopters ?
7. What trigonometric ratio will you use to find d ?
8. Substitute 43 for the angle measure and 2,000 for the opposite side
9. Multiply each side by d
10. Divide each side by sin 43 degrees
11. Use a calculator to simply
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Katresha Davis,
Please refer to the following diagram:
6.) We may find the difference in altitude between the two helicopters by subtracting the altitude of the lower helicopter from the altitude of the higher helicopter:
$$\Delta h=(6000-4000)\text{ ft}=2000\text{ ft}$$
7.) We know the side opposite the given angle, and we are wanting to find the hypotenuse, so we should use the sine function as it relates an angle, the side opposite the angle and the hypotenuse:
$$\sin(\theta)=\frac{\text{opposite}}{\text{hypotenuse}}$$
8.) Using the values in our problem, we may state:
$$\sin\left(43^{\circ} \right)=\frac{2000}{d}$$
9.) Multiplying both sides by $d$, we obtain:
$$d\sin\left(43^{\circ} \right)=2000$$
10.) Dividing both sides by $\sin\left(43^{\circ} \right)$, we get:
$$d=\frac{2000}{\sin\left(43^{\circ} \right)}$$
11.) Using a calculator, we find:
$$d\approx2932.55837127925\text{ ft}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
19K
11K
