Kelvin thermodynamics temperature scale
In summary, the conversation discusses the use of the triple point of water as a reference for the Kelvin scale in defining thermodynamic temperature. This is due to its easy availability and precision in laboratory conditions. The conversation also mentions the possibility of using other reference temperatures and the politics involved in choosing standard units of measure. Additionally, it explores the idea of non-linear temperature scales and the relationship between temperature and kinetic energy.
goggles31
34
The thermal efficiency of a reversible heat engine is solely a function of the temperature of the two reservoirs.
η = f(θHC) = 1 - (QC/QH)
(QC/QH) = 1 - f(θHC)
(QC/QH) = Ψ(θHC)
The simplest function that can be used is T1/T2
(QC/QH) = T1/T2
In order to define the Kelvin scale we assign a value to one of the temperatures and that is the triple point of water, 273.16K. Thus any other temperature is defined as
T = 273.16(Q/Qtp)
My question is, why was the triple point of water used in this equation and can we use any other temperature?
How does this relate to the definition of Kelvin:"The kelvin, unit of thermodynamic temperature, is the fraction 1/273.16 of the thermodynamic temperature of the triple point of water"
If we use another function, say (T1)2/(T2)3, can we stilldefine the Kelvin scale?
In practice, is this equation useful? We could just measure the temperature using a sensor instead of finding the heat transfer at both reservoirs before calculating the temperature.
Science news on Phys.org
The triple point is the reference for the Celcius scale, not the Kelvin scale.
Prior to that, the Fahrenheit scale used the freezing point of a particular mix of brine.
The Kelvin scale uses the intercept of the slope of volume vs temperature with the temperature axis for helium gas.
The reason for choosing the reference is to do with ease of getting the value along with the reproducability of the value and politics.
Water is picked because there is a lot of it easy to get hold of and handle ... brine over pure water because pure water would have been hard to get: but has the disadvantage of requiring care to determine the salinity... so different thermometers using the F scale will have the same number for slightly different temperatures.
You could use the freezing point of pure water ... but that is different for different pressures. The triple point is easy to see and very precise so use that instead.
Both these scales have the advantage of having sane numbers for everyday temperatures.
The Kelvin scale comes from a desire to use the Universe itself as a reference. Find the lowest temperature possible in principle and call that zero.
On top of which - finding absolute zero is now fairly straight forward and can be done accurately.
There are other temperature scales in use. i.e.
https://en.wikipedia.org/wiki/Template:Comparison_of_temperature_scales
Note: you actually need two reference temperatures to set up a scale.
Politics comes into it because standard units and measures are decided by a committee.
Likes Merlin3189
Actually, the triple point of water is used as the one point needed to define the Kelvin as a thermodynamic temperature scale. Water is easily available and the triple point is not hard to achieve in laboratory conditions. This is why it was chosen. Of course other linear thermodynamic scales could be defined, and some have been (See the Rankine scale.) I suppose one could come up with a non-linear scale, but why one would want to do this, I have no idea.
I was just musing that in practise we use the triple point and call it +273.15K, or whatever it is, instead of 0.
You may want a non-linear scale if the physical thermometer has a non-linear response - in a cvgt we are exploiting the change in height of the column being directly proportional to the change in mean kinetic energy of the gas... chosen because of the resulting linearity I guess. iirc the connection beteween temperature and kinetic energy came after the invention of the cvgt so it comes down to what makes for nice maths.
The Kelvin unit was based on the Celsius scale, a change of 1 deg C = 1 K. Ultimately, it was an arbitrary decision.
Strictly: ##1^\circ C = 274.15K## :P (though the distinction would be worth marks in an exam.)
K is C with a different zero point.
"'Lets make the centigrade scale start at absolute zero,' they said - so they ended up with Kelvins. Horrible isn't it."
-- Marvin (the Paranoid) Android (guest lecturing thermodynamics section of physics 101).
Okay, but I don't see how T = 273.16(Q/Qtp) brings about a linear scale. Suppose you fix the hot reservoir at 273.16K. The efficiency of the heat engine would vary depending on the temperature of the cold reservoir because η = (TH-TC)/TH so that both Q and Qtp will change
What @Khashishi was referring to is the unit of temperature difference, not the unit of absolute temperature. In the units of temperature difference, 1 K = 1 °C.
I played around with the numbers a bit and can see what is going on.
Let's assume x joules of energy is moving from the hot reservoir at 273.16K to the heat engine.
η = 1 - TC/273.16
Energy moving into the cold reservoir = x - x(1 - TC/273.16)
= xTC/273.16
T = 273.16(Q/Qtp)
= TC
Amazing...
@DrClaude : quite right - and that distinction is sometimes worth marks in an exam. ;)
Related to Kelvin thermodynamics temperature scale
1. What is the Kelvin temperature scale?
The Kelvin temperature scale is an absolute temperature scale in which zero is defined as absolute zero, the lowest possible temperature. It is based on the properties of an ideal gas at constant pressure, where the lowest possible temperature is associated with zero pressure. The scale is named after William Thomson, 1st Baron Kelvin, who proposed it in 1848.
2. How is the Kelvin scale different from the Celsius scale?
The main difference between the Kelvin and Celsius scales is that the Kelvin scale starts at absolute zero, while the Celsius scale starts at the freezing point of water. This means that on the Kelvin scale, the size of one degree is the same as one degree on the Celsius scale, but the zero point is different.
3. What are the advantages of using the Kelvin scale?
One of the main advantages of using the Kelvin scale is that it is an absolute temperature scale, meaning that it does not have negative values. This makes it easier to perform calculations and compare temperatures. Additionally, the Kelvin scale is often used in scientific and engineering applications because it is directly related to the properties of an ideal gas.
4. How is temperature measured on the Kelvin scale?
The Kelvin scale is measured in units called Kelvin (K). One Kelvin is equal to one degree Celsius, so to convert from Celsius to Kelvin, you simply add 273.15 to the temperature in degrees Celsius. For example, 25 degrees Celsius is equal to 298.15 Kelvin.
5. What is the relationship between Kelvin and other temperature scales?
The Kelvin scale is directly related to the Celsius scale, as one Kelvin is equal to one degree Celsius. It is also related to the Fahrenheit scale, but the conversion is more complicated. To convert from Fahrenheit to Kelvin, you first need to convert to Celsius by subtracting 32 and then multiplying by 5/9. Then, add 273.15 to the result to get the temperature in Kelvin.
  • Thermodynamics
  • Thermodynamics
