MHB Ken's Question from Yahoo Answers: Probability Question For Verification?
  • Thread starter Thread starter CaptainBlack
    Probability
The probability of randomly selecting a point \((x,y)\) within a unit disc that satisfies the conditions \(|x-y| < 1\) and \(|x+y| < 1\) is calculated. The area defined by these inequalities forms an inscribed square with an area of 2, while the area of the unit circle is \(\pi\). Thus, the probability is the ratio of these areas, resulting in \(2/\pi\). The discussion emphasizes that the region of interest is the interior of the square, as demonstrated by the inclusion of the origin point \((0,0)\). Therefore, the correct answer to the probability question is \(2/\pi\).
CaptainBlack
Question:
"A point \({\rm{P}}(x,y)\) is chosen at random in a unit disc, centred at \((0,0)\).
The probability required is that the point chosen is such that both \(| x -y| \lt 1\) and \(|x+y| \lt 1\) .
Is the answer \(2/\pi\) or \(1-2/\pi\)?
Thank you."Answer:
I take disc to be a disc of radius 1 centred at the origin.
The region defined by the inequalities \(|x-y| \lt 1\) and \(|x+y| \lt 1\) is an inscribed square to the circle, which has side \(\sqrt{2}\) and hence area \(2\). The area of the circle is \(\pi\), so the probability that a point sampled uniformly on the unit disc satisfies the inequalities is the ratio of these two area: \(2/\pi\).
To convince yourself that the required region is the interior of the square rather than the exterior consider the point \((0,0)\), does it satisfy the inequalities. It it does then you want the interior of the square rather than the exterior.
Below is a scatter plot showing random points uniformly sampled on the unit disc and in black those satisfying the inequalities:
https://lh3.googleusercontent.com/AsrqIRhjcPwGKPW6RSzDwZRoH0ryjndkugx09Ohv2VkvdbS60GwQ4Gtv2A4qZZSiWoBqxPZVPw
Mathematics news on Phys.org
4LhKv1R4M3w1jH8l0t3A6LJW1z2kQlW4oLJfKQe2-3vW4uw3RrZ-DeQ2k6n1U
So, the answer is indeed \(2/\pi\). I hope this helps!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
11K
