Kepler's First Law of Planetary Motion
In summary, the proof of Kepler's First Law of Planetary Motion using vector valued functions involves showing that the specific angular momentum and eccentricity vector are constants of motion for central motion. The eccentricity vector is only constant for inverse square law central motion. By taking the inner product of the eccentricity vector with the position vector, we can derive the equation of a conic section, which represents the path of a planet around the sun. The equation involves the semi latus rectum, eccentricity, and origin at one of the foci. The proof also relies on the definition of circular unit vectors and the dot product operation.
Brunetto
I'm reviewing my old calculus textbook and I stumbled upon a proof of Kepler's First Law of Planetary Motion which uses vector valued functions along with all of the operations to demonstrate the material. I understand the math and how to to DO it but what I am struggling with is why.
It goes from:
v X h = GM u + c
and then does the dot product of both sides with r.
Why is the above equation "dotted" with r.
This is apparently found in most calculus textbooks but if it is not:
v is the velocity
u is the unit vector of direction
h is a constant vector of rXv
c is a constant vector of integrating u'
The typical approach is to start by showing that the specific angular momentum [itex]\vec h = \vec r \times \vec v[/itex] and the eccentricity vector [itex]\vec e = \vec v \times \vec h / \mu - \hat r[/itex] are constants of motion, where [itex]\mu=GM[/itex].
That [itex]\vec h[/itex] is constant is a direct consequence of central motion, any kind of central motion. That the eccentricity vector is constant is only true for inverse square law central motion, [itex]\vec a = -\mu/r^2 \hat r[/itex].
To show that the eccentricity vector is constant, look at the time derivative of [itex]\vec v \times \vec h[/itex]:
[tex]\begin{aligned}
\frac{d}{dt}(\vec v \times \vec h)
&= \frac{d\vec v}{dt}\times h \\
&= -\frac{\mu}{r^2}\hat r \times \vec h \\
&= -\frac{\mu h}{r^2} \hat r \times \hat h \\
&= \mu\dot{\theta}\hat{\theta} \\
&= \mu\frac{d\hat r}{dt}
\end{aligned}[/tex]
The penultimate step relies upon [itex]h=r^2\dot{\theta}[/itex] and [itex]\hat h \times \hat r = \hat{\theta}[/itex]. The final step relies upon the definition of the circular unit vectors [itex]\hat r[/itex] and [itex]\hat{\theta}[/itex].
From the above, [itex]d/dt(\vec v \times \vec h) = \mu d/dt(\hat r)[/itex], or [itex]d/dt(\vec v \times \vec h - \mu\hat r) = 0[/itex]. Thus [itex]\mu\vec e = \vec v \times \vec h - \mu\hat r[/itex] is a constant of motion.
Now we're at the point where we can take the inner product with the position vector.
\mu\vec e \cdot \vec r
&= (\vec v \times \vec h)\cdot \vec r - \mu \hat r \cdot \vec r \\
&= (\vec r \times \vec v)\cdot \vec h - \mu r \\
&= h^2 - \mu r
\end{aligned}[/tex]
Another way to express the above inner product is in terms of the magnitudes of the two vectors and the angle f between them: [itex]\mu\vec e \cdot \vec r = \mu e r \cos f[/itex]. Equating these approaches yields
[tex]\mu e r \cos f = h^2 - \mu r[/tex]
from which
[tex]r = \frac{h^2/\mu}{1+e\cos f}[/tex]
Defining [itex]p=h^2/\mu[/itex] yields [itex]r=p/(1+e\cos f)[/itex], which is the equation of a conic section with semi latus rectum p, eccentricity e, and the origin at one of the foci.
Related to Kepler's First Law of Planetary Motion
1. What is Kepler's First Law of Planetary Motion?
Kepler's First Law states that the orbit of a planet around the sun is an ellipse, with the sun located at one of the two foci of the ellipse.
2. Who is Kepler and why is his first law important?
Johannes Kepler was a 17th century German astronomer who discovered the three laws of planetary motion, which are fundamental principles in understanding the movement of planets in our solar system. His first law is important because it describes the shape of planetary orbits, which is crucial in understanding the motion of planets.
3. How is Kepler's First Law different from the previous model of planetary motion?
Before Kepler's discovery, it was widely believed that planets moved in perfect circles around the sun. However, Kepler's First Law showed that the orbits of planets are actually elliptical, challenging the previous model of circular orbits.
4. Can Kepler's First Law be applied to other objects in space?
Yes, Kepler's First Law, along with his other two laws, can be applied to any object orbiting around a central body, not just planets. This includes comets, asteroids, and even artificial satellites.
5. How did Kepler come up with his First Law?
Kepler studied the detailed observations of the positions of planets made by fellow astronomer Tycho Brahe. Through his calculations, Kepler realized that the orbit of Mars could not be a perfect circle, leading him to discover the shape of elliptical orbits and formulate his First Law.
19K
