Kerr Black Hole Angular Momentum Limit
In summary, the Schwarzschild metric models the earth's gravity field above its surface well due to Birkhoff's theorem, but it is not a perfect model due to deviations caused by the Earth's rotation. However, the Kerr metric cannot be applied to rotating extended bodies as it does not have an analogue of Birkhoff's theorem and does not account for higher order moments. The Earth itself is an example of this, as it has a detectable quadrupole moment that affects the spacetime geometry around it.
exmarine
241
TL;DR Summary
Could a rotating extended body exceed that limit?
The Schwarzschild metric seems to model, for example, the earth’s gravity field above the earth’s surface pretty well, even though the Earth is not really a golf-ball sized black hole down at the center. Can the same be said for the Kerr metric? Does it model a rotating extended body’s gravity field well above that body’s surface?
(I am wondering about the magnitude of the angular momentum of that extended body versus that of the Kerr black hole. Isn’t there a limit to how much angular momentum the black hole can have, and might the extended body have more than that limit? Or is that not possible?)
Likes Dale
That's because of Birkhoff's theorem: any vacuum spherically symmetric region of spacetime must be a region of Schwarzschild spacetime.
Note that the Earth is not a perfect sphere, though, so the spacetime around it is not exactly modeled by Schwarzschild spacetime; there are deviations. (One of the deviations is that the Earth is rotating--see below.)
No. There is no analogue of Birkhoff's theorem for Kerr spacetime.
Another way of looking at this is: Kerr spacetime has no higher order moments (quadrupole and higher); this follows from the "no hair" theorem. But a real rotating object does have higher order moments, which must be reflected in the spacetime geometry around it. (Note that the Earth itself is an example of this: the Earth has a detectable quadrupole moment, which has been shown to affect the gravitational field and hence the spacetime geometry around it.)
Likes exmarine
Related to Kerr Black Hole Angular Momentum Limit
1. What is the Kerr black hole angular momentum limit?
The Kerr black hole angular momentum limit is a theoretical maximum value for the amount of angular momentum that a black hole can possess. It is named after the physicist Roy Kerr who first described this limit in his solution to Einstein's equations of general relativity.
2. How is the Kerr black hole angular momentum limit calculated?
The Kerr black hole angular momentum limit is calculated using the formula J = GM^2/c, where J is the angular momentum, G is the gravitational constant, M is the mass of the black hole, and c is the speed of light. This formula takes into account the mass and spin of the black hole.
3. What happens if a black hole exceeds the Kerr black hole angular momentum limit?
If a black hole exceeds the Kerr black hole angular momentum limit, it is predicted that it will become unstable and start to emit gravitational waves. This is known as the superradiant instability and is a consequence of the black hole's strong gravitational pull on surrounding matter.
4. Is the Kerr black hole angular momentum limit the same for all black holes?
No, the Kerr black hole angular momentum limit varies depending on the mass and spin of the black hole. Smaller black holes have a lower limit, while larger black holes have a higher limit. However, all black holes are subject to this limit and cannot exceed it.
5. How does the Kerr black hole angular momentum limit affect the behavior of matter near the black hole?
The Kerr black hole angular momentum limit can affect the behavior of matter near the black hole by causing it to orbit around the black hole in a specific direction. This is known as frame dragging and is a result of the black hole's strong gravitational pull and high spin. It can also lead to the formation of accretion disks around the black hole.
