Killing vectors corresponding to the Lorentz transformations
In summary, the conversation discusses the computation of Killing vectors using the Lorentz group and the vicinity of the unit matrix. The result includes a line that is not understood, which is explained to be due to the antisymmetry of the epsilon matrix and the (a)symmetry of alpha and beta in the functional derivative. An example in 1+1D Minkowski space is given to illustrate the computation.
wafelosek
Hi everyone! I have a problem with one thing.
Let's consider the Lorentz group and the vicinity of the unit matrix. For each ##\hat{L}##
from such vicinity one can prove that there exists only one matrix ##\hat{\epsilon}## such that ##\hat{L}=exp[\hat{\epsilon}]##. If we take ##\epsilon^{μν}##, μ<ν, as the parameters on the Lorentz group in a vicinity of the unit matrix, then we can compute the corresponding Killing vectors as ##\xi ^μ_{αβ}=\frac{∂x′^μ}{∂ϵ^{αβ}}(\hat{ϵ}=0)## where ##x′^μ=L^μ_νx^ν##. Here is my problem: during the computations there is one line that I do not get, namely: ##\cfrac{∂L^{μν}}{∂ϵ^{αβ}}(\hat{ϵ}=0)=δ^μ_αδ^ν_β−δ^μ_βδ^ν_α##. The ## (\epsilon^{μν}) ## matrix is antisymmetric, so that is why we get the difference of the Kronecer delta?
Thank you in advance!
MW
Yes. That partial derivative is defined such that the (a)symmetries of alpha and beta are the same on the left and right hand side. You can also check explicitly by taking e.g. alpha=0, beta=1.
Because that page treats a general matrix where the components are all independent, this is not the case for the Lorentz group generators.
So, to extend a little bit on Orodruin's remark: in this case, the antisymmetry in alpha and beta indicates that not all the components are independent. So if you then define the functional derivative of a tensor with respect to that epsilon, you get an expression containing again indices alpha and beta. By definition, these components are then still considered to be dependent. This means the (a)symmetry carries over in the functional derivative.
Or, rephrased: the (a)symmetry has to be respected on the left and right hand side in the definition of the functional derivative.
To expand a little on the little expansion, just with a hands-on example, consider the Lorentz transformations in 1+1D Minkowski space, where you would have
\hat \epsilon = \begin{pmatrix}0 & \epsilon_{01} \\ - \epsilon_{01} & 0 \end{pmatrix}.
Differentiating ##\hat L = \exp(\hat\epsilon)## with respect to ##\epsilon_{01}## would give you
\frac{\partial \hat L}{\partial \epsilon_{01}} = \frac{\partial \hat \epsilon}{\partial \epsilon_{01}} \hat L,
which evaluated in ##\epsilon = 0## leads to
\left. \frac{\partial \hat L}{\partial \epsilon_{01}}\right|_{\epsilon = 0} = \begin{pmatrix}0 & 1 \\ -1 & 0\end{pmatrix}.
You will find that this satisfies your relation.
Related to Killing vectors corresponding to the Lorentz transformations
1. What are Killing vectors corresponding to the Lorentz transformations?
Killing vectors are mathematical objects used in the study of symmetries in physics. In the context of Lorentz transformations, Killing vectors are vector fields that generate the infinitesimal transformations of the Lorentz group.
2. How do Killing vectors relate to the Lorentz transformations?
Killing vectors correspond to the generators of the Lorentz group, which is a group of transformations that preserve the spacetime interval in special relativity. These vectors play a crucial role in understanding the symmetries and properties of spacetime.
3. What is the significance of Killing vectors in physics?
Killing vectors are important in physics because they represent the symmetries of a system. In the context of Lorentz transformations, Killing vectors represent the symmetries of spacetime, which are crucial in understanding the laws of physics, such as conservation laws and the behavior of particles.
4. How are Killing vectors calculated for Lorentz transformations?
Killing vectors can be calculated using mathematical techniques such as Lie algebra and differential equations. In the case of Lorentz transformations, the Killing vectors are related to the generators of the Lorentz group, which can be calculated using specific matrices and operations.
5. What are some applications of Killing vectors in physics?
Killing vectors have various applications in physics, such as in the study of black holes, cosmology, and quantum field theory. They are also used in the development of mathematical models and theories in physics, such as the Standard Model and general relativity.
