KiloNewton/Pound foot of thrust into Horsepower units
In summary, arjun is asking for help converting different units of measurement into each other. He is specifically looking for help with converting engine thrust into horsepower and watts. He states that this is a very basic conversion and he is struggling to derive precise equations. He has found information on google and wikipedia, but would appreciate help from an expert.
Arjun Singh
53
Hi,
I am currently studying aviation engine outputs and to make my study linear in comparative analysis with standard Automotive engines I need some expert help.
Can anyone help me drive precise equations to convert:
1. Engine thrust in Kilo Newton into Horse Power and Watts
2. Engine thrust in Pound foot into Horse power and Watts
3. Watts into Horse Power.
Seems very basic conversion yet I am struggling to derive precise equations for these statement queries.
Would be great if someone can help me out in this.
Thanks
Arjun
Thrust and power are different quantities and can't be directly related. You will need to know more about the propulsion system to find the power at a given thrust. Are we talking jets or propellers?
Also, pound-foot is not a unit of thrust...
BvU said:
Hello arjun, :welcome:
wattts to horsepower
Did you know you can simply google these things :rolleyes: ?
An obvious observation. Google as an introductory ideation tool is providing extremely complex correlations while I require very basic yet elemental overview. Perhaps I answered your question now can you help solve mine.
Jets. On wikipedia in design spec of jet engines, the output efficiency is described in pound foot. Is it not the correct denotion? Also aint the horse power and shaft horse power same notions to describe engine output.
I don't see it, can you link/quote the article you are reading please.
They are, but jet engines don't have an output shaft...do you mean turboprop/turboshaft engines?
I was just addressing your jet or propeller question, as propellers would be turboprop/turboshaft engines.
https://en.wikipedia.org/wiki/Mikoyan-Gurevich_MiG-25
See the powerplant spec in Specifications section.
Maybe it would be instructive to look at an engine like the General Electric CF6/LM2500, which has both thrust and shaft producing versions. They aren't identical, but it might get you in the ballpark.
What is LP? Also can you help me with the equations query posted earliest in this thread.
Arjun Singh said:
What is LP?
I don't know, where are you seeing that?
As I said, there is no such equation. These are not comparable units/performance metrics.
In the GE engine article you shared, turbine and compressor specifications have HP that is horse power and LP... so what is that?
That's not horsepower in the wiki article for the CF6 - that's RPM. The specification table shows max LP RPM (maximum rotational speed of the low pressure [LP] shaft and components) and max HP RPM (maximum rotational speed of the high pressure [HP] shaft and components). For horsepower, you need to look at the LM2500.
Likes russ_watters
Ok. Thanks. Can you help me with this -
As has already been explained to you.
1) There is no direct thrust to horsepower conversion. They're fundamentally different kinds of units.
2) Pound foot isn't a thing. When you see lbf in a specification for a jet engine, that's pounds force.
3) Watts to horsepower is easy. It's 746 (if I remember right) watts per horsepower. You can look this up on google in 10 seconds.
Likes jbriggs444, BvU and russ_watters
Thanks. I had seen the watts to horsepower conversion. Just wanted to confirm.
Power = thrust * velocity
So you need to know how fast the engine/aircraft is moving when it makes the specified thrust. If it not moving then technically it's not producing any useful output power, although it is producing a lot of power in the form of waste heat and moving air.
One more
Yes. I was trying to understand various engine output comparisons between various aircrafts in an attempt to understand what factors affect the type of an engine selected for a specific aircraft. Also how an aviation jet engine output is comparable to a scale down piston engine or electric motor simply in terms of generated speed of the vehicle. So my logic was that thrust is basically force and force=weight x acceleration. And power (watts) = force x velocity. So was trying to derive a standard watt equation using thrust but couldn't. Also, some engines do have HP in their engine spec, so was trying to work out a logic for these two different specifications. One observation that I made is that turbo shaft and turbo prop engines in many articles do have HP as their output unit and almost all high output turbojet and turbofan engines have thrust as the unit. Is it because of the high output of the later mentioned engines? Also thrust beyond an output denotion didn't seem to have any relative values for standard unit conversions. My queries may seem elementary level so pardon the indulgence.
No, it's because turboshaft and turboprop engines have output shafts and jet engines just move air.
OK. Thanks for your help guys. Appreciated.
Note that you can get to a level of detail on modern jet engines where horspower is useful - specifically if you look at the power required to drive the compressor, front fan, etc, but that's all internal to the engine. Just as a point of comparison though, the power required to drive the front fan on a large modern jet engine can be in the ballpark of 100,000 horsepower.
That's a very ambitious number. I was thinking in the range of 20,000 to 25000 HP. Also is the thrust produced by the entire engine (combination of this fan and the resultant exhaust from the compressor and combustion chamber) has any mathematical relativity to the shaft HP of the fan it is powering.
I'll admit that I'm just going off memory, but I think that number is about right. That having been said, it doesn't really have any relevance to the performance of the jet engine, it's just part of the internal design. As for your question, no there's not really any direct relation between thrust and fan power. You might be able to construct some relation if you also account for bypass ratio and design cruise speed or something, but it's certainly not just a direct HP to thrust relation.
If it helps... The RR Trent 60 gas turbine for power generation is around 60MW.
Cool. Will check it out. Let's see what relevant I can find to add to this discussion.
Good - that's sort of in line with my memory, since that's around 80,000 horsepower, and the Trent 60 is a bit smaller than the GE90 engine that I remembered the number above from.
So another point in the discussion. I was going through an article about a gigantic locomotive used as an ore carrier for mining. Apart from its size and design what was very unique about this machine was that it worked with a electric wheeler system where apart from the gear and clutch system that propels the vehicle there is also an auxiliary electric system drawing its power from an electric motor that is part of the engine power plant, and is coupled with the wheels to facilitate functions like braking, skid protection and the most interesting as an extra power above the gear system for the wheels through AC alternators and four AC traction motors (two in each axle).
https://en.wikipedia.org/wiki/BelAZ_75710
So is such a system applicable to aviation engines, especially high-by-pass turbofans? What I mean is, is the fuel-electric powerplant applicable to aviation or are the conventional mechanical systems most ideal and safest? If I am not mistaken, I don't think Fuel-electric systems make the engine any lighter in weight.
Your description seems a bit tough to follow, but what is described in the link is a series hybrid, where the diesel engines don't provide any propulsion, they only turn generators, which then power electric drive motors.
Such systems are common on trains as well because they generate near full torque all the way down to zero RPM. Trains - and this mining truck - need high torque at low RPM.
Ships can also be powered this way.
Aircraft engines tend to need high rpm and low torque, so I wouldn't expect this to be a beneficial performance profile for aircraft.
Likes Arjun Singh
Electric motors in the power range to replace aircraft engines tend to be extremely heavy, so I wouldn't expect them to be usable as a replacement for gas turbine engines (which are very light for their power output) anytime soon. In addition, as Russ said, the benefit of their use in trains, heavy equipment, etc, is that you can run the engine at a high power, high-efficiency setting all the time and then use the electric motor to run at a wide variety of speeds without the need for a large transmission. However, for an aircraft, the engine runs pretty close to one setting the whole time anyways, so you don't need that variability.
Likes russ_watters
  • #31
It's worth noting that for that vehicle, the electric system isn't auxiliary. Rather, there is no gear and clutch system at all. The 2 diesel engines simply power generators, and all vehicle motion comes from the electric motors attached to the axles. This saves a large amount of space, weight, and complexity since clutch and transmission mechanisms for that much power would be extremely large.
  • #32
Perhaps I was a bit creative with my understanding of the spec. Does a hybrid power plant also improve the maintenance requirement of the assembly? I think it does.
  • #34
No.
force = MASS * acceleration
12K
9K
