Kinda help Probability function - E(2^X)?
The left side is the sum of pr etr for r= 1, 2, 3, and 5 while the right side is the mgf. Setting t= 1, 2, 3, and 5 will give us 4 equations to solve for the 4 unknowns: p, q, r, and s.Using t= 1, we
Tomp
27
Kinda urgent help! Probability function - E(2^X)??
Question A moment-generating function of X is given by M(t) = 0.3e^t + 0.4e^(2t) + 0.2e^(3t) + 0.1e^(5t)
Find the pmf of X
My solution
x f(x)
1 0.3
2 0.4
3 0.6
5 0.1
The next question asks
Calculate E(2^X)
Which I am totally unsure about
I calculated the mean as 0.22 and variance as 5.28
Can someone provide any clues on what to do to answer this?
My notes and textbook do not have any examples or notes similar to this :S
Thanks in advance
Find the pmf of X
My solution
x f(x)
1 0.3
2 0.4
3 0.6
5 0.1
Calculate E(2^X)
The mean and variance of what? The problem asked just for E(2^X) which is, by definition,
2^1(0.3)+ 2^2(0.4)+ 2^3(0.6)+ 2^5(0.1).
That was using the values you give. What happened to x= 4?
Thanks in advance
It hard to believe your textbook does not tell how to find expectation!
Find the pmf of X
My solution
x f(x)
1 0.3
2 0.4
3 0.6
5 0.1
Calculate E(2^X)
Thanks in advance
Your probabilities are incorrect: their sum is 0.3 + 0.4 + 0.6 + 0.1 = 1.4. Perhaps you made a simple typo.
Suppose the pmf is P[X=r] = pr. How would you write E[etX] in terms of t and the pmf? What do you get if you equate that expression to the given mgf?
Related to Kinda help Probability function - E(2^X)?
What is the formula for the Kinda help Probability function - E(2^X)?
The formula for the Kinda help Probability function - E(2^X) is E(2^X) = ∑x2^xP(X=x), where P(X=x) is the probability of the random variable X taking on the value x.
What does E(2^X) represent in terms of probability?
E(2^X) represents the expected value or mean of the random variable 2^X. It is the average value that we would expect to see if we were to repeat the experiment many times.
How is the Kinda help Probability function - E(2^X) calculated?
The Kinda help Probability function - E(2^X) is calculated by multiplying each possible value of X by its corresponding probability and then summing up all of these products. This is known as the expected value formula.
What does the value of E(2^X) tell us about the distribution of X?
The value of E(2^X) tells us about the central tendency of the distribution of X. It represents the most likely outcome or the average outcome of the experiment.
Can the Kinda help Probability function - E(2^X) be used to make predictions?
Yes, the Kinda help Probability function - E(2^X) can be used to make predictions about the outcome of an experiment. It gives us a measure of the expected value, which can be useful in decision making and forecasting.
