Kinematic problem: VERY complicated
  • Thread starter mclame22
  • Tags
    Kinematic
In summary, a helicopter carrying Dr. Evil with a constant upward acceleration of 5.0m/s² takes off and secret agent Austin Powers jumps on. After struggling for 10.0s, Powers shuts off the engine and steps out, causing the helicopter to be in free fall. The maximum height reached by the helicopter is 380m. Powers deploys a jet pack after 7.0s and has a constant downward acceleration of 2.0m/s². When the helicopter crashes into the ground after 9.50s, Powers is 60m above the ground.
mclame22
A helicopter carrying Dr. Evil takes off with a constant upward acceleration of 5.0m/s². Secret agent Austin Powers jumps on just as the helicopter lifts off the ground. After the two men struggle for 10.0s, Powers shuts off the engine and steps out of the helicopter. Assume that the helicopter is in free fall after its engine is shut off and ignore effects of air resistance.
a) What is the maximum height above ground reached by the helicopter?
b) Powers deploys a jet pack strapped on his back 7.0s after leaving the helicopter, and then he has a constant downward acceleration with magnitude 2.0m/s². How far is Powers above the ground when the helicopter crashes into the ground?
Vf = Vi + at
Vf² = Vi² + 2ad
d = Vit + 1/2at²
I already did part a. to this problem and the maximum height reached by the helicopter is 380m (correct answer). The second part is driving me batty; I've been going at it for over 2 hours. This is what I've done so far, but I just can't get the right answer.
HELICOPTER:
Velocity of helicopter when Powers jumps out:
Vf = Vi + at
Vf = (0m/s) + (+5.0m/s²)(10.0s) = +50.0m/s
Time taken for helicopter to reach max height:
Vf = Vi + at
t = (Vf - Vi)/a = (0m/s - 50.0m/s)/(-9.8m/s²) = 5.10s
Time taken for helicopter to crash from max height:
Vf = Vi + at
d = Vit + 1/2at²
(-380m) = (0m/s)t + 1/2(-9.8m/s²)t²
t² = 380m/19.6m/s²
t = 4.40s
Total time from when Powers jumps out until crash:
t total = 5.10s + 4.40s = 9.50s
POWERS:
Velocity of Powers right before he uses jet pack:
Vf = Vi + at
Vf = (+50m/s) + (-9.8m/s²)(7.0s) = -18.6m/s
Distance Powers has fallen before using jet pack:
Vf² = Vi² + 2ad
(-18.6m/s)² = (+50m/s)² + 2(-9.8m/s²)d
d = -109.9m
Time until crash right as Powers uses jet pack:
Total time from when Powers jumps out until crash = 9.50s
Time taken to use jet pack = 7.0s
Time until crash right as jet pack is used = 9.50s - 7.0s = 2.50s
Distance traveled by Powers from using jet pack until crash:
d = Vit + 1/2at²
d = (-18.6m/s)(2.50s) + 1/2(-2.0m/s²)(2.50s)²
d = -210.25m
Total distance Powers has fallen when helicopter crashes = -109.9m - 210.25m = -320.15m
Height of Powers when helicopter crashes = 380m - 320.15m = 59.85m = 60m
The online assignment is not accepting this as an answer. What am I doing wrong? Was I supposed to take Power's initial velocity as he jumped from the helicopter as being 0m/s?
I think you're not doing it correctly.
The helicopter rises with a constant acceleration to reach max height, for a given time.
They give you both a and t. Period. Why do you mess it with gravity g ?
t² = 380m/19.6m/s²
Looks like it should be t² = 380/4.9
Vf² = Vi² + 2ad
d = -109.9m
Check the calc; I get +110. Due to the high initial velocity Powers goes up, not down. Check with
d = di + Vi*t + .5*a*t² = 250 + 50*7 - 4.9*7² = 360 m above ground.
Quinzio: I did take the +5.0m/s^2 acceleration into consideration for when the engine was on.. Then the helicopter was under the influence of gravity alone when the engine cut off.
Thanks Delphi51, I did do a few calculations wrong. I ended up getting an answer of 180m which was correct. Thank you for your help!
If so, why?
Dear student,
First of all, great job on part a! It seems like you have a good understanding of kinematics and are on the right track for part b. Let's go through your solution and see where the problem might be.
For the helicopter, you correctly calculated the time it takes for it to reach maximum height. However, in your next step, you used the wrong acceleration (-9.8m/s²). Remember, the helicopter is in free fall after the engine is shut off, so the acceleration should be -9.8m/s². This means that your time for the helicopter to reach maximum height is also incorrect. It should be t = (0m/s - 50.0m/s)/(-9.8m/s²) = 5.10s, which you already calculated in your solution.
Your next step for calculating the time for the helicopter to crash is correct, but you made a small mistake in your calculation of the distance traveled by Powers before using the jet pack. It should be d = (-18.6m/s)²/(2(-9.8m/s²)) = 17.6m. This is because the initial velocity is not 50m/s, but rather the velocity right before Powers uses the jet pack (-18.6m/s).
For the time until the crash right as Powers uses the jet pack, you calculated it correctly, but your calculation for the distance traveled by Powers is incorrect. It should be d = (-18.6m/s)(2.50s) + 1/2(-2.0m/s²)(2.50s)² = -48.75m.
Now, let's add up all the distances traveled by Powers: -109.9m + 17.6m + (-48.75m) = -140.05m. This is the total distance traveled by Powers when the helicopter crashes. To find his height, we need to subtract this from the maximum height reached by the helicopter, which is 380m. This gives us 380m - (-140.05m) = 520.05m.
So, Powers is 520.05m above the ground when the helicopter crashes. The closest answer choice to this is 520m, so that should be your final answer.
In summary, the main mistakes in your solution were using the wrong acceleration for the helicopter and making small mistakes
Related to Kinematic problem: VERY complicated
What is a kinematic problem?
A kinematic problem is a type of physics problem that involves the motion of objects without considering the forces that cause the motion. It focuses on describing the position, velocity, and acceleration of an object at different points in time.
What makes a kinematic problem "very complicated"?
A kinematic problem can be considered "very complicated" when it involves multiple objects moving in different directions, changing speeds, and/or accelerating at different rates. Additionally, the inclusion of other factors like air resistance or friction can also make a kinematic problem more complex.
What are the key equations used in solving kinematic problems?
The key equations used in solving kinematic problems are the equations of motion, which include the equations for position, velocity, and acceleration. These equations are based on the concepts of displacement, time, and acceleration, and can be used to describe the motion of an object in a particular system.
What are some common strategies for solving kinematic problems?
Some common strategies for solving kinematic problems include setting up a coordinate system, identifying known and unknown variables, and using the equations of motion to solve for the unknown values. Drawing diagrams, using algebraic manipulation, and checking for units and consistency are also important strategies for successfully solving kinematic problems.
How can I check if my solution to a kinematic problem is correct?
To check if your solution to a kinematic problem is correct, you can perform a dimensional analysis to ensure all units are consistent. Additionally, you can also use common sense and logic to see if your solution makes sense in the context of the given problem. Finally, you can compare your solution with the expected answer or use a calculator to confirm your calculations.
12K
