Kinematic question from giancoli
  • Thread starter nobelium102
  • Tags
    Kinematic
In summary, the conversation discusses the calculation of water speed as it leaves a hose nozzle pointed vertically upward, taking into account the acceleration of gravity. The resulting speed is found to be 9.05 m/s, and the conversation also addresses the question of why the acceleration remains constant at -9.81 m/s^2 even as the water goes up and then falls down.
nobelium102
66
Suppose you adjust your garden hose nozzle for a hard stream of water. You point the nozzle vertically upward at a height of 1.5 m above the ground (the hose is 1.5 m off the ground). When you quickly move the nozzle from the vertical you hear the water striking the ground next to you for another 2.0 s. What is the water speed as it leaves the nozzle?
my attempt s = ut+1/2 at^2
-1.5 = u(2) + 1/2(-9.8)(4)
u = 9.05 m/s
and it is right
but the question is that why is the acceleration still -9.8m/s^2 when the water is going up and then falling down?
The acceleration is always downward so it is negative. It means the upward speed decreases steadily at a rate of 9.8 m/s every second. Initially the upward speed is 9.05 m/s. After 1 second, it is 9.05-9.81 = -.76 m/s. That is just after the maximum height where the speed is zero. After two seconds, the upward speed is -.76 - 9.81 = -10.57 m/s, which is the speed just before hitting the ground.
oh man i didn't understand at first but i think i kind of get it
you are saying that acceleration has decreased so much that it became negative direction?
right?
hope this is right
I can explain the reason for the acceleration remaining constant at -9.8m/s^2. This is due to the force of gravity acting on the water as it moves in a vertical direction. According to Newton's laws of motion, an object in motion will continue to move in the same direction and with the same speed unless acted upon by an external force. In this case, the external force acting on the water is gravity, which causes it to accelerate towards the ground at a rate of -9.8m/s^2. Therefore, even though the water is initially moving upwards, it will eventually slow down and fall back down towards the ground due to the acceleration caused by gravity. This is why the acceleration remains constant throughout the motion of the water.
FAQ: Kinematic question from giancoli
1. What is kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion. It focuses on describing the position, velocity, and acceleration of objects in motion.
2. How is kinematics related to dynamics?
Kinematics and dynamics are both branches of classical mechanics. Kinematics focuses on describing the motion of objects, while dynamics studies the causes of motion, such as forces and energy.
3. What are the basic equations of kinematics?
The three basic equations of kinematics are the equations for displacement (Δx = xf - xi), velocity (v = Δx/Δt), and acceleration (a = Δv/Δt). These equations can be used to solve for any one of the variables if the other two are known.
4. How can kinematics equations be applied to real-world situations?
Kinematics equations can be applied to real-world situations to analyze and predict the motion of objects. For example, they can be used to calculate the time it takes for a ball to reach the ground when thrown from a certain height, or the velocity of a car at a certain point in time.
5. What are some common units used in kinematics?
Some common units used in kinematics include meters (m) for distance, meters per second (m/s) for velocity, and meters per second squared (m/s^2) for acceleration. Other units, such as kilometers per hour (km/h) and miles per hour (mph), may also be used depending on the situation.
18K
