Kinematics: Ball thrown off of a building
In summary: So when it says "x direction" it means "horizontal".but if the question doesn't say anything about the angle, how can you assume it?It's not so much assuming as interpreting. It seems clear that the problem setter intended that the ball was thrown horizontally, and therefore that the problem is about the vertical motion of the ball.
DracoMalfoy
88
A ball is thrown off of a building in the +x direction at 10m/s. If the ball takes 2s to land, how tall is the building?
  • Vf=Vi(a)(t)
  • Δd=Vi(t)+1/2(a)(t)
  • Vf^2=Vi^2+2(a)(Δd)
  • Δd=1/2(Vf-Vi)(t)
  • Vf: 0m/s
  • Vi: 10m/s
  • a: -9.8m/s^2
  • t: 2s
  • Δd: ?
I tried using the second, third and fourth equation to find the displacement but I keep getting 5 or 5.1 or a number a bit lower and none of those are the answers.
the choices are
A. 19.6m
B. 5.1m
C.33.3m
D. 2m
E. 1m
DracoMalfoy said:
  • Vi: 10m/s
  • a: -9.8m/s^2
The equations you quote are for motion in one straight line. What is the geometric relationship between the a and vi quoted above?
i have projectile motion equations but the question doesn't come with an angle so I got confused
Make a sketch
Oh, and: show your work in detail. I can't reconstruct ##\approx## 5 m no matter how hard I try
BvU said:
Make a sketch
i made a hideous sketch lol. I am not sure how to do this when I am not given an angle
If it says "in the +x direction", then what is the angle ?
And: please show your work in detail. I can't reconstruct ≈ 5 m no matter how hard I try
Am I repeating myself ?
Try calculating it with a few selected angles to get the range of possible answers.
Vertically up,
horizontal
Vertically down
The real answer has to lie somewhere in that range.
Note: that investigation will show that the question is imperfect - one answer MUST be wrong, 4 of them COULD be correct, but will also indicate which situation the questioner had in mind when setting this question - and thus the probably answer.
Note also: When they said the ball was thrown in the +x direction, I believe a direction was given - or at least strongly implied..
The angle is implied.
When it says "x direction" it is assuming the standard use of x, y, z in 3D Earth surface problems: z is vertical, x and y are horizontal.
Related to Kinematics: Ball thrown off of a building
1. How do you calculate the initial velocity of a ball thrown off of a building?
The initial velocity of a ball thrown off of a building can be calculated using the equation v = √(2gh), where v is the initial velocity, g is the acceleration due to gravity (9.8 m/s²), and h is the height of the building.
2. What is the equation for calculating the maximum height reached by a ball thrown off of a building?
The maximum height reached by a ball thrown off of a building can be calculated using the equation h = (v₀²sin²θ)/(2g), where h is the maximum height, v₀ is the initial velocity, θ is the angle of the throw, and g is the acceleration due to gravity.
3. How does air resistance affect the motion of a ball thrown off of a building?
Air resistance can affect the motion of a ball thrown off of a building by slowing down its velocity and causing it to reach a lower maximum height. This is because air resistance creates a force that acts opposite to the direction of motion, reducing the overall acceleration of the ball.
4. Does the mass of the ball affect its motion when thrown off of a building?
According to the equations of kinematics, the mass of the ball does not affect its motion when thrown off of a building. However, in real-world scenarios, the mass of the ball may have a small impact on its velocity and trajectory due to air resistance and other external factors.
5. How can the final velocity of a ball thrown off of a building be calculated?
The final velocity of a ball thrown off of a building can be calculated using the equation v = v₀ + at, where v is the final velocity, v₀ is the initial velocity, a is the acceleration due to gravity, and t is the time the ball has been in motion.
