Kinematics-Boulder Falling Problem
  • Thread starter SChiO
  • Tags
    Falling
In summary, the question asks for the approximate distance a boulder will fall in 2 seconds, discounting air friction. The equation x-x_0 = v_0t + 1/2at^2 is used to solve this problem, with the acceleration due to gravity (g) being the only force acting on the boulder. The initial speed of the boulder is assumed to be zero, and thus the answer is 20m (A). The equation used is valid for objects experiencing constant acceleration.
SChiO
I'm not sure if this is the right place to post this but I need help understanding this question...
Discounting air friction, approximately how far will the boulder have fallen in 2 seconds?
a. 20m
b. 45m
c. 30m
d. 90m
Now I know this is just a plug and chug equation and the answer is 45m (B). My question is more in understanding the physics behind using this equation...
Originally i used a=Δv/Δt then plugged my found velocity into v=d/t but that gives me 40m, which is not an option.
How do I know when to use which?
Thanks for any help in clarifying this for me! :D
"Discounting air friction, approximately how far will the boulder have fallen in 2 seconds?"
Is that the entire question, or did they give any specifics as the the boulders initial speed? If the initial speed is zero, then you are considering tthe case in which an object has started at some position above the ground. You should be thinking about just as the boulder starts to fall, and what is happening during the fall.
While the boulder is in free fall, what is governing the speed at which its falling?
No other information was given. A picture of a boulder falling near a cliff was the only other thing given.
But while the boulder is in free fall isn't it just gravity that's controlling the speed?
Yes.what else do you know about the problem?
EDIT: I'm sorry, what your first attempt should have given you is the correct answer as well. you may have just made an arithmetic error. both [itex] x = v_0t + \frac{1}{2}at^2 [/itex] and manipulating [itex] a = \frac{v_f - v_i}{t_f - t_i} [/itex] and using [itex] v = \frac{d}{t} [/itex] yield the same results
Oh I see...well if the only force really acting on the boulder is gravity that means i have constant acceleration, right? And I'm now remembering that the correct equation for this problem is one used under constant acceleration...
Yes, now if we let the downward direction be the positive direction, then we see that, like you said, [itex]a = g[/itex].
so the equation now becomes [itex] x-x_0 = v_0t + \frac{1}{2}gt^2 [/itex].
so you know that the only force acting on the boulder is gravity and thus it is experiencing constant acceleration. but you also know the initial speed, right?
Likes 1 person
As he said earlier,the value of initial speed is not given. Only a diagram is given. So you can safely assume the velocity to be zero. If my assumption IS correct,then the answer is A) 20m/s
Yes, That's what I was getting at and why I said SChiO must have made an arithmetic error. I just didn't want to give it away. I can only assume SChiO figured it out by now..
FAQ: Kinematics-Boulder Falling Problem
What is kinematics?
Kinematics is the branch of physics that deals with the motion of objects without considering the cause of the motion.
What is the "Boulder Falling Problem"?
The "Boulder Falling Problem" is a classic physics problem that involves calculating the time it takes for a boulder to fall a certain distance under the influence of gravity.
What are the key concepts in solving the "Boulder Falling Problem"?
The key concepts in solving the "Boulder Falling Problem" are acceleration due to gravity, initial velocity, and displacement.
How do you calculate the time for a boulder to fall a certain distance?
The time for a boulder to fall a certain distance can be calculated using the equation t=√(2d/g), where t is time, d is distance, and g is acceleration due to gravity (9.8 m/s² on Earth).
What are some real-life applications of the "Boulder Falling Problem"?
The "Boulder Falling Problem" has real-life applications in fields such as engineering, construction, and sports. For example, engineers use this problem to determine the time it takes for a building to collapse in an earthquake, while athletes use it to calculate the height of their jumps.
