Kinematics bowling ball problem
A bowling ball traveling at constant speed hits pins at the end of a 10 m lane, with the bowler hearing the sound of the impact 3 seconds after release. The total time is the sum of the time taken for the ball to reach the pins and the time for the sound to travel back. Using the speed of sound (340 m/s), the time for sound to travel 10 m is calculated as approximately 0.0294 seconds. Substituting this into the total time equation allows for the calculation of the ball's speed, resulting in approximately 3.4 m/s. The discussion emphasizes the importance of correctly applying kinematic equations to solve the problem.
physicsss
319
a bowling ball traveling with constant speed hits the pins at the end of a bowling lane 10 m long. The bowler hears the sound of the ball hitting the pins 3 sec after the ball is released from his hands. What is the speed of the ball? (Speed of sound is 340 m/s)
Can someone give me a hint? I know it involves d=v*t, but I don't know how I can use the speed of sound and the time when the ball hits the pins besides finding the distance the ball traveled...
thanks in advance
The total time between releasing the ball and hearing the sound of the ball hitting the pin is given as 3 seconds. This time, T, is the sum of t1, the time it takes the bowling ball to go down the lane, and t2, the time it takes for the sound to travel 10m. (T = t1 + t2) for t2, v = a = d/t2, where a is the speed of sound and d is 10 m. The same equation goes for t1: vball = d/t1. (the speed of the ball is unknown) To put it all together, solve for t1 and t2 and plug back into the first equation I wrote. I hope that helps.
tell me if I'm on the right track...
3=t1+t2
3=t1+(d/v)
3=t1+10/340
t1=2.97
d=vt
10=v*2.97
v=3.4 <-velocity of the ball
Looks good except for the second line, which looks like a typo. Speaking of which, I had a typo in my original post (fixed now, sorry about that). Anyway, good job.
Fixed, and thank you so much for the help.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
