Kinematics - Calculating Distance
  • Thread starter Insolite
  • Tags
    Kinematics
In summary, the conversation involves a man falling from the top of a tall building and the calculation of the height h of the building. Various methods have been attempted but the final correct solution involves using the equation of motion and solving a quadratic equation to arrive at the answer of 175m. The mistake made was assuming that the time to travel 3/4 of the distance was equal to 3/4 of the total time, when in fact it is equal to the square root of 3/4 of the total time.
Insolite
Question: "A man steps from the top of a tall building. He falls freely from rest to the ground, a distance of h. He falls a distance of h/4 in the last 0.800 s of his fall. Neglecting air resistance, calculate the height h of the building.
I've attempted the solution in a number of different ways, each of which give different answers.
Solution:
I have labelled the initial time (i.e. at the instant before he begins to fall) as ##t_{0}##, the time at which he has traveled ##\frac{3}{4}## of the total distance h as ##t_{1}## and the time at which he has traveled the full height h as ##t_{2}##.
Using the equation ##x = x_{0} + v_{0}t + \frac{1}{2}a_{x}t^{2}##, where ##x = h##, ##t = t_{2}## and ##a_{x} = g##.
##x_{0} = 0## as no distance has been traveled whilst the man is still at the top of the building
##v_{0}t = 0## as the initial velocity at the top of the building is zero
Therefore -
## h = h_{0} + v_{0}t_{2} + \frac{1}{2}gt_{2}^{2}##
## h = 0 + 0 + \frac{1}{2}gt_{2}^{2}##
## h = \frac{1}{2}gt_{2}^{2}##
Re-arranging to give -
##t_{2} = \sqrt{\frac{2h}{g}}##
##(t_{2} - t_{1})## = the time to travel ##\frac{1}{4}h = 0.800 s##
##(t_{1})## = the time to travel ##\frac{3}{4}h = \sqrt{\frac{2h}{g}} - 0.800 s##
Substituting the value of ##t_{2}## for ##h## in the latter of these equations gives -
##\frac{3}{4}\sqrt{\frac{2h}{g}} = \sqrt{\frac{2h}{g}} - 0.800 s##
Therefore 0.800 must be equivalent to ##\frac{1}{4}\sqrt{\frac{2h}{g}}##
##0.800 = \frac{1}{4}\sqrt{\frac{2h}{g}}##
##3.20 = \sqrt{\frac{2h}{g}}##
##h = \frac{3.20^{2}g}{2}##
##h = 50.2 m##
I believe that my mistake is in assuming that ##(t_{1}) = \sqrt{\frac{2h}{g}} - 0.800 s## is equivalent to ##\frac{3}{4}h\sqrt{\frac{2h}{g}}##, as the man's velocity increases with constant acceleration and therefore ##\frac{3}{4}## of ##t_{2}## does not correspond to having traveled ##\frac{3}{4}h##.
However, I'm uncertain how else to approach the problem. I have tried other methods involving heavier use of the equations of motion with constant acceleration and have twice calculated h as ≈ 12 m, but this would not be a tall building! (I realize that the actual answer does not always have to accurately reflect the real-world scenario described in the question, but I believe I should use it as guidance in evaluating my answer.)
Any help and/or advice would be greatly appreciated.
Yes, exactly. Up to the point of this assumption everything was correct. And you even know the reason. solve for ##t_{1}## just like you solved for ##t_{2}## but this time take the height to be ##\frac{3}{4}h##. Now, substitute this value and solve. You'll arrive at the answer.
P.S. : ##t_{1}=\sqrt{\frac{3h}{2g}}##
Hi, thankyou for your response.
I had approached the problem this way previously, but for some reason or another I discarded it.
I have tried to run it through and have calculated what I think is a reasonable answer -
##t_{1} = \sqrt{\frac{3h}{2g}}## (derived from the equation of motion used previously using ##\frac{3}{4}h## as ##x##)
##(t_{2} - t_{1}) = 0.800 s##
##t_{2} - (t_{2} - t_{1}) = t_{1}##
##\sqrt{\frac{2h}{g}} - 0.800 s = \sqrt{\frac{3h}{2g}}##
##{\left(\sqrt{\frac{2h}{g}} - 0.800 s\right)}^2 = {\left(\sqrt{\frac{3h}{2g}}\right)}^2##
## \frac{2h}{g} - 1.6\sqrt{\frac{2h}{g}} + 0.64 = \frac{3h}{2g}##
##\frac{h}{2g} - 1.6\sqrt{\frac{2h}{g}} + 0.64 = 0##
Solving the quadratic equation using the following substitutions -
##u = \sqrt{2h}## and ##u^{2} = 2h##
##\frac{1}{4g}u^{2} - \frac{1.6}{\sqrt{g}}u + 0.64 = 0##
Using the quadratic formula -
##x = -\frac{b\pm\sqrt{b^{2}-4ac}}{2a}##
##u \approx 18.7026##
##u \approx 1.3429##
##u = \pm\sqrt{2h}##
##h = 175 m##
I hope I haven't made any errors, please correct me where appropriate. I realize that I should try to keep the value of u as an exact number for use in further calculation, but I kept making mistakes when trying to input values in my calculator and found it easiest to right down the values of a, b and c to high precision for use in the formula, as the final answer is required to only three significant figures.
Thanks again for your input :smile:
##h = 175 m##
Yes, its correct. And you have managed to separate out the real solution from the unreal one.
P.S. : Separating the roots is done by checking the values in the original equation involving ##t_{1}## and ##t_{2}##
Your approach to solving this problem is correct, but there is a small mistake in your calculation for ##t_{1}##. Instead of ##\frac{3}{4}\sqrt{\frac{2h}{g}}##, it should be ##\sqrt{\frac{2h}{g}} - \sqrt{\frac{h}{g}}##. This is because the man is falling for ##\frac{3}{4}## of the total time, which is equal to ##\sqrt{\frac{h}{g}}##. This will give you a value of h that is closer to the expected answer.
In general, it is always good to check your answer against the given information to see if it is reasonable. In this case, the man falls a distance of ##\frac{h}{4}## in the last 0.800 s, so the total time of his fall should be approximately 3.200 s. If your calculated value for h gives a total time significantly different from 3.200 s, then you know there is an error in your calculation.
Additionally, you can also use the equation ##v = v_{0} + at## to check your answer. At the top of the building, the man's initial velocity is 0 m/s. Using the value of h that you calculated, you can plug it into the equation to find the final velocity at the bottom of the building. This should give you a value close to the expected final velocity of the man hitting the ground, which is approximately 28 m/s.
Overall, your approach to solving this problem is correct, and it is important to double check your calculations and use the given information to ensure that your answer is reasonable. Keep up the good work!
Related to Kinematics - Calculating Distance
1. How is distance calculated in kinematics?
In kinematics, distance is calculated by multiplying the magnitude of an object's displacement by the direction it moves. This can be represented by the formula distance = speed x time.
2. What is the difference between distance and displacement in kinematics?
Distance refers to the total length an object has traveled, whereas displacement refers to the straight-line distance between the object's starting position and ending position. Displacement takes into account both the magnitude and direction of an object's movement, while distance does not.
3. Can you calculate distance if you only know the speed and time?
Yes, distance can be calculated using the formula distance = speed x time. As long as you have values for both speed and time, you can determine the distance an object has traveled.
4. How does acceleration affect the calculation of distance in kinematics?
Acceleration is the rate of change of an object's velocity. This means that when an object accelerates, its speed and direction are changing. In kinematics, distance is calculated based on an object's speed, so any changes in acceleration will affect the distance traveled over a given time period.
5. What units are used to measure distance in kinematics?
In kinematics, distance is typically measured in units of length, such as meters or kilometers. However, it can also be measured in other units depending on the specific situation, such as feet or miles. The unit of measurement used for distance will depend on the context in which it is being calculated.
