Kinematics Electrons In a Cathode Ray Tube
In summary, a cathode ray tube (CRT) is a vacuum tube that accelerates electrons from a cathode to an anode, creating a focused beam that can be controlled by electric and magnetic fields. Kinematics is used to describe the motion of electrons in a CRT, and these electrons are controlled by adjusting the intensity and direction of the electric and magnetic fields. CRTs have been used in various applications, but have largely been replaced by newer technologies.
nycjay222
A) In a cathode ray tube, electrons are accelerated from rest by a constant electric force of magnitude 6.22 x 10−17 N during the first 2.00 cm of tube's length; then they move at essentially constant velocity another 46.5 cm before hitting the screen. Find the speed of the electrons when they hit the screen.
B)How long does it take them to travel the length of the tube?
Before you ask for any help, you have to show your attempts.
We are here to help you in understanding the Physics.
We can't do your home work.
A) To find the speed of the electrons when they hit the screen, we can use the kinematic equation v^2 = u^2 + 2as, where v is the final velocity, u is the initial velocity (in this case, 0 m/s), a is the acceleration (in this case, the constant electric force), and s is the distance traveled (in this case, 48.5 cm). Plugging in the values, we get v = √(0^2 + 2(6.22 x 10^-17 N)(0.485 m)) = 1.41 x 10^6 m/s. This is a very high speed, which is expected for electrons accelerated by a strong electric force.
B) To find the time it takes for the electrons to travel the length of the tube, we can use the kinematic equation s = ut + 1/2at^2, where s is the distance traveled (48.5 cm), u is the initial velocity (0 m/s), a is the acceleration (6.22 x 10^-17 N), and t is the time. Solving for t, we get t = √(2s/a) = √(2(0.485 m)/(6.22 x 10^-17 N)) = 6.97 x 10^-9 s. This is a very short amount of time, which is expected for electrons traveling at high speeds in a cathode ray tube.
Related to Kinematics Electrons In a Cathode Ray Tube
1. What is a cathode ray tube (CRT)?
A cathode ray tube (CRT) is a vacuum tube that is used to create images on screens, such as computer monitors and television screens. It works by using a high voltage to accelerate electrons from a cathode to an anode, which creates a focused beam of electrons that can be controlled by electric and magnetic fields.
2. How do electrons move in a cathode ray tube?
In a CRT, electrons are emitted from a heated cathode and are accelerated towards the anode by a high voltage. The electrons are then focused by electric and magnetic fields and directed towards a fluorescent screen, where they create an image by striking phosphors on the screen.
3. What is the role of kinematics in a cathode ray tube?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion. In a cathode ray tube, kinematics is used to describe the motion of electrons as they are accelerated and focused by electric and magnetic fields.
4. How are electrons controlled in a cathode ray tube?
Electrons in a cathode ray tube are controlled by varying the intensity and direction of the electric and magnetic fields. These fields can be adjusted using electrodes and magnets, allowing for precise control of the electron beam and the images it creates on the screen.
5. What are the practical applications of cathode ray tubes?
Cathode ray tubes have been used in a wide range of applications, including television and computer monitors, oscilloscopes, and medical imaging devices. While they have largely been replaced by newer technologies, CRTs are still used in certain specialized applications where their high resolution and ability to produce bright images are advantageous.
  • Quantum Physics
10K
  • Electrical Engineering
14K
