Kinematics - finding time given height and acceleration
In summary, the height of a helicopter is given by h = 2.50t^3 where h is in meters and t is in seconds. After 2.45 s, the helicopter releases a small mailbag. Using the kinematic equation d = vt + 1/2at^2, we can calculate that the mailbag has an initial velocity of 45.0 m/s and will reach the ground after 2.74 seconds.
indietro
46
The height of a helicopter above the ground is given by h = 2.50t^3 , where h is in meters and t is in seconds. After 2.45 s, the helicopter releases a small mailbag. How long after its release does the mailbag reach the ground?
d=v1t +1/2at^2
So i found the height of the helicopter at 2.45s which also = the distance the bag must fall:
=2.5(2.15)^3
= 36.8 m
then since the bag is in free fall it has an acceleration of 9.8m/s^2
and i just assume that the velocity is 0 because it is being drop from the helicopter.
so using kinematic equation: d=v1t +1/2at^2
rearrange for time and plugging in:
t^2= 36.8/4.9
t = 2.74s
can someone just check that my reasoning is correct? that would be great thanks :)
Well, since the helicopter is moving, the bag will have a (non-zero) initial velocity. So if you can figure out the helicopter's velocity at 2.45s, then you can use that for v1.
im not sure if I am finding velocity correctly...
so d = 36.76 m
a = 9.8 m/s^2
t = 2.45 s
plug into kinematic equation: d= vt + 1/2at^2 = 3 m/s
or do i not use gravity as acceleration because the helicopter could be accelerating...??
The helicopter is rising, not falling with gravity. Also, its acceleration is not constant; since a is not constant, those equations for constant acceleration do not work for the helicopter.
Have you had calculus? The derivative would be helpful in figuring out the helicopter's velocity here.
ok so the velocity of the helicopter h'= 7.5t^2 , plugging in 2.45s means the bag has in initial velocity of 45.0 m/s ...?
Yes.
FAQ: Kinematics - finding time given height and acceleration
What is kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion. It deals with the mathematical description of motion, including concepts such as displacement, velocity, and acceleration.
What is the formula for finding time given height and acceleration?
The formula for finding time given height and acceleration is t = √(2h/g), where t is the time, h is the height, and g is the acceleration due to gravity (9.8 m/s² on Earth).
What are the units for time, height, and acceleration in kinematics?
The units for time, height, and acceleration in kinematics are seconds (s) for time, meters (m) for height, and meters per second squared (m/s²) for acceleration.
Can kinematics be used to predict an object's future motion?
Yes, kinematics can be used to predict an object's future motion by analyzing its current position, velocity, and acceleration. However, it assumes that there are no external forces acting on the object.
What are some real-life applications of kinematics?
Kinematics has many real-life applications, including predicting the trajectory of a projectile, analyzing the motion of planets and other celestial bodies, designing roller coasters and other amusement park rides, and studying the movement of vehicles such as cars, airplanes, and rockets.
