Kinematics in 1D: Will Defiance Drake reach the ship or miss?
In summary, the problem statement is unclear and presents some conflicting information. It is important to clarify the initial velocity and acceleration directions as well as the direction of movement for Defiance. Drawing a diagram can help visualize the situation and determine the appropriate values to use in calculations.
CJoy
Defiance Drake, Space Adventurer, desperately needs to reach a cargo vessel 100m away, or run out of air and die in deep space. For our purposes, there are two relevant directions, the direction Defiance is traveling in (the x-direction, at 1 m/s), and direction of the cargo ship's motion, which is perpendicular to her motion (y-direction, 10 m/s). Defiance uses her jet boots, choosing to accelerate directly in the x-direction at 0.25g (she starts at (x=100,y=0)). If the cargo vessel is 25 m long, and its nose cone starts at x=0,y=0, will Defiance reach the ship or miss? If she misses, how should she have chosen her path (assume she cannot exceed 1 g)?
V(t)=Vo+AoT
X(t)=VoT+1/2AoT
0.25g converts into 2.45m/s^2
V(t)=Vo+AoT
1=0+2.45T
T=1/2.45
T=0.4s
X(t)=VoT+1/2AoT
X(t)=100+0+1/2(2.45)(0.4)^2
X(t)=100.196m
I don't know if this is the right methodology or how to move on from here
Likes Delta2
I think you misunderstood something. The way I read it, Defiance' initial velocity is 1 m/s, and then accelerates from there. Also, acceleration and velocity carry with them directions. You need to take this into account: for example, is the velocity causing X(t) to increase with time or decrease? What about the acceleration?
Also, what value of time should you use to see if she makes it there in time? Try drawing a picture to help you visualize this.
The problem statement is a bit confusing on this. We are told that Defiance's initial velocity and acceleration are in the "x-direction". Does this mean in the positive x-direction following the convention that positive signs are omitted? But then if she starts on the positive x-axis, is initially moving away from the cargo vessel and accelerates also away from it, guess what? If we are to assume that Defiance is not stupid and accelerates in the negative direction towards the cargo vessel (despite the statement of the problem) can we then override the problem once again and assume that her initial velocity is also negative or do we take it as positive?
Likes scottdave
Related to Kinematics in 1D: Will Defiance Drake reach the ship or miss?
1. Will Defiance Drake reach the ship?
It is impossible to accurately predict whether Defiance Drake will reach the ship without more information about his starting position, velocity, and the distance to the ship.
2. What is Kinematics in 1D?
Kinematics in 1D is the study of motion in one dimension, specifically the position, velocity, and acceleration of an object.
3. How is Kinematics in 1D different from Kinematics in 2D or 3D?
Kinematics in 1D focuses on motion in a straight line, while Kinematics in 2D and 3D involve motion in multiple dimensions and directions.
4. What factors affect an object's ability to reach its destination?
The object's initial position, velocity, acceleration, and the distance to its destination are all factors that can affect whether an object will reach its destination.
5. Can Kinematics in 1D be applied to real-life situations?
Yes, Kinematics in 1D is used in many real-life situations, such as calculating the distance traveled by a car or the time it takes for a ball to roll down a hill.
