Kinematics involving an airplane
In summary, the bomb released from an airplane at an attitude of 14400 ft and a speed of 600 miles per hour will travel a horizontal distance of 5 miles before hitting the ground. The calculation involves using the formula for distance traveled with no air resistance and the Pythagorean theorem. The diagonal distance from the point of release to the plane is not relevant in finding the horizontal distance.
davedave
50
A bomb is dropped from an airplane at an attitude of 14400 ft. The plane is moving at 600 miles per hour. How far will the bomb move horizontally after it is released from the plane?
I use the formula involving the distance traveled by an object with no air resistance and the Pythagorean theorem.
(1) d= vt - 0.5gt^2
(2) a^2 + b^2 = c^2
1 mile = 5280 ft
g = 32 ft/sec^2
the plane's speed = 600 miles per hours = 880 ft per sec
Assuming that the airplane has no vertical velocity, I let v = 0 in the first equation above.
Then, -14400 = -(0.5)(32)(t^2)
Solving for t gives t = 30 sec.
Next, the diagonal distance from the point at which the bomb is on the ground to the plane is
(880)(32)=28160 miles.
To find the horizontal distance traveled by the bomb, I use the Pythagorean formula
horizontal distance = square root of (28160^2 - 14400^2) = 24200 ft = 4.58 miles
My answer is wrong. The answer key says 5 miles. What did I do wrong?
Please explain it. Thank you very much
Your work for the first part is correct the time is 29.9 seconds to reach the ground. For the second part what you did is incorrect the path is a parabola so the diagonal distance is not what you wrote there.
To find the horizontal displacement use d = vxit + 1/2 ax t2
You know the initial velocity in the x direction, and you know that the acceleration is zero since the only force acting on the body is the downward weight
davedave said:
1 mile = 5280 ft
g = 32 ft/sec^2
Always pay attention to the units you are using.
880 is in feet/second.
It's not clear if 32 represents g in ft/s2 or if it is supposed to be the time of fall of 30 seconds.
In any event, the result does not come out in units of miles. 28160 miles is larger than the diameter of the earth!
How did you get the diagonal distance by multiplying the horizontal speed with the gravitational attraction?
Anyway, the key thing here is that the horizontal distance traveled by the bomb only depends on the horizontal component of it's velocity. The horizontal distance is unaffected by the vertical component. Thus when the bomb leaves the plane it has a horizontal velocity of 880 ft/sec and the time for the journey as you found out was 30 sec. Therefore horizontal distance traveled is [itex] 880 \frac{ft}{s} * 30 s = 26400 ft = 5 miles [/itex]
FAQ: Kinematics involving an airplane
What is kinematics involving an airplane?
Kinematics involving an airplane is the study of the motion and movement of an airplane, including its position, velocity, and acceleration.
What is the difference between linear and angular kinematics in relation to an airplane?
Linear kinematics refers to the motion of an airplane in a straight line, while angular kinematics refers to the rotation and movement of the airplane around a fixed point.
How is the speed of an airplane calculated?
The speed of an airplane is calculated by dividing the distance traveled by the time it takes to travel that distance. It is typically measured in miles per hour (mph) or meters per second (m/s).
What factors affect the acceleration of an airplane?
The acceleration of an airplane can be affected by various factors, including the engine power, air resistance, and the angle of the airplane's wings (known as the angle of attack).
How does the motion of an airplane differ during takeoff, cruising, and landing?
During takeoff, an airplane experiences a significant increase in velocity and acceleration as it gains enough speed to lift off the ground. During cruising, the airplane maintains a constant speed and altitude. During landing, the airplane gradually reduces its speed and descends to the ground.
