MHB Kinematics, particle on half circle
A particle traverses half a circle of radius 160 cm in 10 seconds, prompting calculations for mean velocity and acceleration. The main confusion arises around the mean vector of total acceleration, particularly if constant tangent acceleration is assumed. It is suggested that if the initial angular velocity is zero, the mean acceleration simplifies to a formula involving only normal acceleration. However, the discussion reveals that assuming zero initial angular velocity may overlook variations in acceleration, indicating a potential loss of generality in the assumptions made.
Fantini
MHB
Here's the problem.
A point traversed half a circle of radius $R = 160 \text{ cm}$ during a time interval of $\tau = 10.0 \text{ s}$. Calculate the following quantities averaged over that time:
(a) the mean velocity $\langle v \rangle$;
(b) the modulus of the mean velocity $ |\langle {\mathbf v} \rangle|$;
(c) the modulus of the mean vector of the total acceleration $| \langle {\mathbf w} \rangle |$ if the point moved with constant tangent acceleration.
I'm having trouble with (c). Since he mentioned there is a constant tangent acceleration I assumed it is non-zero (this may not be the case). I did not manage to reach a conclusion. Assuming it is zero, the mean acceleration is merely the mean normal acceleration. This leads to
$$| \langle {\mathbf w} \rangle | = 2 | {\mathbf w}_n | = 2 \frac{\langle v \rangle^2}{R} = 2 \frac{\pi^2 R}{\tau^2}.$$
I'm missing something, because the alleged answer is
$$| \langle {\mathbf w} \rangle | = \frac{2 \pi R}{\tau^2} \approx 10 \frac{\text{cm}}{\text{s}^2}.$$
Thank you. :)
Mathematics news on Phys.org
Fantini said:
Here's the problem.
Thank you. :)
Hey Fantini! ;)
Let $\alpha$ be the angular acceleration, which is constant.
Let $\omega_0$ be the initial angular velocity.
And let $0 \le \theta \le \pi$.
Then:
= \left| \frac{\Delta \mathbf v}{\Delta t} \right|
= \left| \frac{\mathbf v(\pi) - \mathbf v(0)}{\tau} \right|
= \frac{|-R(\alpha\tau + \omega_0) + R\omega_0|}{\tau}
= R\alpha$$
Furthermore, we have:
$$\theta(\tau) = \frac 12 \alpha \tau^2 + \omega_0 \tau = \pi$$
$$\alpha = \frac{\pi - \omega_0\tau}{\frac 12 \tau^2}$$
So:
= R\frac{\pi - \omega_0\tau}{\frac 12 \tau^2}
=\frac{2\pi R}{\tau^2} - \frac{2\omega_0 R}{\tau}$$
Apparently your problem assumes that $\omega_0=0$.
Hey ILS! :)
This is problem 1.19 from Irodov's Problems in General Physics, 1988. Is there any loss of generality by assuming $\omega_0 = 0$? It seems not, since the circular movement begins after $t=0$.
Thank you for your insightful input. ;)
Fantini said:
Hey ILS! :)
You are right that we can assume $t=0$ without loss of generality.
However, since $|\langle \mathbf w \rangle|$ changes with $\omega_0$, it seems to me that there is loss of generality. So I don't understand where this assumption is coming from.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
