Kinematics problem with differential equations.
In summary, the conversation discusses a particle's acceleration as a function of x, with the given equation a(x)=(2.0 s-2)*x. The first question asks for the speed of the particle when x=3.0m, given that the velocity is zero when x=1.0m. The second question asks for the time it takes for the particle to travel from x=1.0m to x=3.0m. The attempts at a solution involve using the equations a=dV/dt and V=dx/dt to find the velocity at x=3.0m and the time it takes to travel from x=1.0m to x=3.0m.
Spoti112
Suppose the acceleration of a particle is a function of x, where a(x)=(2.0 s-2)*x.
(a) If the velocity is zero when x= 1.0 m, what is the speed when x=3.0 m?
(b) How long does it take the particle to travel from x=1.0 m to x=3.0 m. a(x)=(2.0 s-2) * x
(a) V(x=3) = ? , V(x=1) = 0
(b) t=? (from x=1 to x=3)
a=dV/dt
V=dx/dt
(a) a = dV/dt = (dV/dx) * (dx/dt)= (dV/dx) * V ⇒
⇒ a = 2x = (dV/dt) * V ⇒ VdV = 2xdx ⇒ ∫VdV = ∫2xdx ⇒
⇒ V2/2 = x2 + c
x=1↔V=0 ⇒ 0=12 + c ⇒ c = -1
⇒ V=√( 2 * (x2 - 1) ) ⇒ V(x=3) = 4 m/s
(b) i have no idea... ;(
Can you combine these:
Spoti112 said:
V=dx/dt
Spoti112 said:
V=√( 2 * (x2 - 1) )
dx/dt = √( 2 * (x2 - 1)) → dt = dx/√(2(x2 - 1)) ... and i`m stuck with the math
if i integrate here in an interval of 1 to 3 (both sides ) , won't i lose the t in the equation ?
The 1 to 3 is the x range. The t range is the duration, from tx=1m=0 to t=tx=3m.
thank you very much for the help!
FAQ: Kinematics problem with differential equations.
What is kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion. It describes the position, velocity, and acceleration of objects in terms of time.
What are differential equations?
Differential equations are mathematical equations that describe the relationship between a function and its derivatives. They are used to model various physical phenomena, including motion and change.
How are kinematics problems solved using differential equations?
Kinematics problems can be solved using differential equations by setting up equations that represent the motion of the object and then solving for the unknown variables using calculus techniques. These equations can be solved analytically or numerically using computer software.
What are some common types of kinematics problems that use differential equations?
Some common types of kinematics problems that use differential equations include problems involving constant acceleration, projectile motion, circular motion, and simple harmonic motion.
What are the applications of solving kinematics problems using differential equations?
Solving kinematics problems using differential equations has many practical applications in fields such as engineering, physics, and astronomy. It can be used to predict and analyze the motion of objects in various scenarios, such as designing a roller coaster or predicting the trajectory of a satellite.
