How Far Will a Puck Slide with Friction?
In summary, a force of friction of 3.2N acting on a 1.1Kg puck with an initial velocity of 7.5 m/s will cause the puck to travel a distance of 2.58m before coming to rest. However, this calculation is incorrect as it does not take into account the non-constant velocity of the puck.
Anuj Agarwal
A force of friction of 3.2N acts on a 1.1Kg puck while it is sliding along a horizontal surface. If the initial velocity of the puck was 7.5 m/s, how far will the puck travel before coming to rest?
The answer is 9.7M. Tried multiple time with different formulas but unable to derive at solution.
Hi @Anuj Agarwal, Welcome to Physics Forums.
You need to show us at least one of your attempts in detail or your thread will be deleted. Just saying you tried and failed does not give us any basis upon which to help you.
Sorry. Here is my try: F =mxa hence a = f/m=3.2/1.1=2.9
A=v/s, hence s=v/a =7.5/2.9=2.58
Distance = velocityxtime = 7.5x2.58=19.3 m
The last line is wrong. This would only be true if the velocity were constant. The fact that your answer is twice as big as it should be should give you a clue.
Related to How Far Will a Puck Slide with Friction?
1. What is friction in kinematics?
Friction is a force that opposes the motion of an object when it comes into contact with another object or surface. In kinematics, friction is often described as a force that acts in the opposite direction of an object's motion.
2. How does friction affect an object's motion in kinematics?
Friction can slow down an object's motion, cause it to stop, or change its direction. The amount of friction depends on the roughness of the surfaces in contact and the force pressing the objects together.
3. What factors affect the amount of friction in kinematics?
The amount of friction is affected by the roughness of the surfaces in contact, the force pressing the objects together, and the type of material the surfaces are made of. Other factors such as temperature and humidity can also affect the amount of friction.
4. How is friction calculated in kinematics?
Friction can be calculated using the coefficient of friction, which is a ratio of the force required to move an object over a surface to the weight of the object. The coefficient of friction can vary depending on the materials in contact and can be determined through experiments.
5. How can friction be reduced in kinematics?
Friction can be reduced by using lubricants such as oil or grease, which create a layer between the two surfaces and reduce the amount of contact between them. Smoother surfaces or adding wheels or ball bearings can also reduce friction in kinematics.
