ahsanxr
- 350
- 6
A submarine can use sonar (sound traveling through water) to determine its distance from other objects. The time between the emission of a sound pulse (a “ping”) and the detection of its echo can be used to determine such distances. Alternatively, by measuring the time between successive echo receptions of a regularly timed set of pings, the submarine’s speed may be determined by comparing the time between the echos to the time between pings. Assume you are the sonar operator in a submarine traveling at a constant velocity underwater. Your boat is in the eastern Mediterranean Sea, where the speed of sound is known to be 1522 m/s. If you send out pings every 2.00 s, and your apparatus receives echoes reflected from an undersea cliff every 1.98 s, how fast is your submarine traveling?
What I did was I tried to find the distance the cliff was from the submarine (1522x0.99)=1506.78 m. Although I'm not sure whether this applies when the submarine is moving. I am stuck and do not know what to do next. Please help me out.
