Kinematics Question - Need Help Desperately
  • Thread starter Joe_K
  • Tags
    Kinematics
In summary, the problem involves an unsuspecting bird traveling east at 1.34 m/s and experiencing a constant acceleration of 0.200 m/s^2 from a south wind for 3.90 seconds. The task is to find the magnitude and direction of the bird's displacement during this time period. The problem can be solved by treating the x and y-directions as independent and computing the total displacement using vector components.
Joe_K
33
An unsuspecting bird is coasting along in an easterly direction at 1.34 m/s when a strong wind from the south imparts a constant acceleration of 0.200 m/s^2. If the acceleration from the wind lasts for 3.90s, find the magnitude, r, the direction, theta, of the bird's displacement during this time period. (HINT: assume the bird is originally traveling in the +x direction)
I missed a day of class, and I am not really sure what the equations are that I am supposed to use for this type of question. Can anyone help me get going on this problem? Thanks in advance.
The problem is much like the usual projectile kind of problem. There's an initial velocity in the x-direction and an acceleration in the y-direction. The motions are independent. Compute both over the given time interval. Treat as vector components for the total displacement.
Thank you for your help, I am still a little confused as to what you mean by "compute over the given time interval"
What's the x-direction displacement after the stated time? What's the y-direction displacement after the given time?
I would suggest that you first start by defining the problem and identifying the known and unknown variables. In this case, the problem is asking for the magnitude and direction of the bird's displacement after experiencing a constant acceleration from the wind. The known variables are the initial velocity of the bird (1.34 m/s), the acceleration from the wind (0.200 m/s^2), and the time period (3.90s). The unknown variables are the magnitude (r) and direction (theta) of the bird's displacement.
Next, you can use the equations of kinematics to solve for the unknown variables. In this case, you can use the equation r = r0 + v0t + 1/2at^2, where r0 is the initial position, v0 is the initial velocity, a is the acceleration, and t is the time period. Since the bird is initially traveling in the +x direction, the initial position (r0) can be assumed to be 0.
Plugging in the known values, we get r = 0 + (1.34 m/s)(3.90s) + 1/2(0.200 m/s^2)(3.90s)^2 = 5.23 m. This is the magnitude of the bird's displacement.
To find the direction, we can use the equation theta = tan^-1(vy/vx), where vy is the final vertical velocity and vx is the final horizontal velocity. In this case, the bird is not experiencing any vertical acceleration, so vy remains 0. Therefore, the direction theta = tan^-1(0/1.34) = 0 degrees.
So, the bird's displacement is 5.23 m in the +x direction. I hope this helps you with your homework. It is important to understand the equations and how to use them to solve problems in kinematics. Good luck!
FAQ: Kinematics Question - Need Help Desperately
What is kinematics?
Kinematics is the branch of physics that studies the motion of objects without considering the forces that cause the motion.
What are the basic equations of kinematics?
The three basic equations of kinematics are:
1. v = u + at (for calculating final velocity)
2. s = ut + 1/2at^2 (for calculating displacement)
3. v^2 = u^2 + 2as (for calculating final velocity without time)
How do I solve a kinematics problem?
To solve a kinematics problem, you need to identify the known and unknown variables, choose the appropriate equation(s) to use, and plug in the values to solve for the unknown variable. It is also important to carefully consider the direction of motion and properly assign positive and negative signs to the values.
What is the difference between linear and rotational kinematics?
Linear kinematics deals with the motion of objects along a straight line, while rotational kinematics deals with the motion of objects around an axis or center of rotation.
Can kinematics be applied to real-life situations?
Yes, kinematics can be applied to real-life situations such as calculating the trajectory of a projectile, the speed and acceleration of a moving car, or the motion of a roller coaster. It is used in fields such as engineering, sports, and transportation to understand and improve the motion of objects.
