Kinematics question: Projectile trajectory given velocity, height at one instant
In summary, the conversation discusses finding the maximum height, horizontal distance, and velocity of a ball that is shot into the air from the ground. Different methods are suggested, including using the equation v^2=vo^2+2a(dy) to find the final vertical component of velocity and considering the entire trajectory from 8.3m to the ground in one calculation. Rounding errors are also mentioned as a potential issue.
edgarpokemon
93
Thread title amended to be more descriptive of the problem
A ball is shot from ground into the air. at height 8.3m, its velocity is 7.8i + 6.5j. Find Maximum height rise, horizontal distance traveled and magnitude of velocity just before the ball hits the ground.
So i got the total height. i got 10.45. My question is in part of magnitude of velocity as it hits the ground. So if the ball reaches a height of 10.45m, then would i use v^2=vo^2+2a(dy) to find final vertical component of velocity. So if the ball reaches a maximum height of 10.45m. then isn't dy=10.45? it says in the solution that i should use 8.3m for dy, but why? if the ball is at 10.45?
What is the ball's velocity when it has just returned to 8.3m height?
that would be -6.5m/s. but why would it not work like i want to do it? I noticed that at 10.45, the ball will not have the same speed of 6.5, but greater. so if i calculate the velocity at 10.45 then can i solve for the final velocity of j as the ball hits the ground? problaby not jaja, but why not?
Yes, that will work, provided you use the right value for v0 there.
However, there is a disadvantage in this method. In declaring the max height to be 10.45 you would have done some rounding. Using that as the starting point for the next stage of calculation unnecessarily introduces some inaccuracy. For that reason, it would be better to start again and consider the whole trajectory from height 8.3m to ground in one calculation. Or use Simon's method, which produces the same equation.
It would totally work but what haruspex said about rounding errors.
At y=10.45m the speed should be less, not more... but both approaches should give the same answers for the speed when the ball hits the ground.
You use the same equation, but vo is different.
There are a number of different approaches. None are more right than the others but some are easier and less prone to error.
aaaa i see i guess i over thinked it too much! i understand now oh my goshhh thanks!
Related to Kinematics question: Projectile trajectory given velocity, height at one instant
1. How do you calculate the initial velocity of a projectile?
The initial velocity of a projectile can be calculated using the formula v0=√(2gh), where v0 is the initial velocity, g is the acceleration due to gravity (9.8 m/s2), and h is the height at which the projectile was launched.
2. What is the equation for projectile trajectory?
The equation for projectile trajectory is y = y0 + xtan(θ) - (gx2)/(2v02cos2θ), where y is the vertical displacement, y0 is the initial height, x is the horizontal displacement, θ is the launch angle, g is the acceleration due to gravity, and v0 is the initial velocity.
3. How do you find the maximum height of a projectile?
The maximum height of a projectile can be found using the formula hmax = (v02sin2θ)/(2g), where hmax is the maximum height, v0 is the initial velocity, θ is the launch angle, and g is the acceleration due to gravity.
4. Can the height of a projectile be negative?
Yes, the height of a projectile can be negative if it is launched below the reference point (usually the ground). This would indicate that the projectile is below the reference point at that particular point in time.
5. How does air resistance affect projectile trajectory?
Air resistance can affect projectile trajectory by slowing down the projectile's velocity, causing it to travel a shorter distance and have a shorter range. It can also alter the shape of the trajectory, making it more curved instead of a perfect parabola. This is because air resistance creates a force that acts in the opposite direction of the projectile's motion, slowing it down and changing its direction.
