Kinetic and Potential energy pendulum problem
In summary, the conversation discusses a problem where a 3-kg mass is attached to a light string and given an initial speed of 4 m/s. The question asks to find the change in potential energy, the speed of the mass, and the maximum height reached by the mass. The solution involves using the equations for potential and kinetic energy, and setting up a right triangle to find the height. The difference in potential energy is due to rounding, with the book retaining more significant figures.
BrainMan
279
A 3-kg mass is attached to a light string of length 1.5 m to form a pendulum. The mass is given a initial speed of 4 m/s at its lowest position. When the string makes and angle of 30° with the vertical, find (a) the change in potential energy of the mass, and (B) the speed of the mass (c) What is the maximum height reached by the mass above its lowest point?
PE= mgy
KE=1/2mv^2
I was able to solve and get correct all parts of this problem except (a).I attempted to find the answer by finding the total energy using KE=1/2mv^2. I found the total energy to be 24 J. Then I found the height of the pendulum at 30 degrees by doing 1.5 cos 30°. Then I subtracted that value from 1.5 to find the height. I then did 3(9.8)(.2) to find the change in potential energy. I got 5.88 and the books answer says its 5.91 J.
Have you tried simply using trig? Set up a right triangle with theta at the vertex of the pendulum.
EDIT* Oh wait..
I also got ~5.91 actually 5.908 but w/e.
(1.5m - 1.5cos(30))(3)(9.8)
But it's not actually .2, your difference comes from dropping off those decimal places. Wait until the very end to round.
You did it right. Just bad rounding.
Likes 1 person
The answer in the book comes from retaining more than 2 significant figures from the result of the cosine. That is, the book set ##1.5 - (1.5\; \cos 30^\circ)## equal to 0.2009619##\ldots## instead of 0.20, as you did. Both ways are acceptable, although I prefer keeping more figures in intermediate results.
Likes 1 person
OK I see what I did wrong. Thanks!
FAQ: Kinetic and Potential energy pendulum problem
1. What is kinetic energy in a pendulum?
Kinetic energy in a pendulum refers to the energy of motion that is possessed by the pendulum bob as it swings back and forth. It is directly related to the mass and velocity of the pendulum bob.
2. How is potential energy calculated in a pendulum?
Potential energy in a pendulum is calculated as the product of the mass of the pendulum bob, the acceleration due to gravity, and the height of the bob above its resting position. This calculation is based on the principle of conservation of energy.
3. What factors affect the kinetic and potential energy of a pendulum?
The kinetic and potential energy of a pendulum are affected by the mass of the pendulum bob, the length of the pendulum, and the amplitude of the pendulum's swing. These factors determine the speed and height of the pendulum bob, which in turn affect its kinetic and potential energy.
4. How does the energy of a pendulum change as it swings back and forth?
As a pendulum swings back and forth, its energy constantly changes between kinetic and potential energy. At the highest point of its swing, the pendulum has maximum potential energy and minimum kinetic energy. At the lowest point of its swing, the pendulum has maximum kinetic energy and minimum potential energy.
5. Can the energy of a pendulum be conserved?
Yes, the energy of a pendulum can be conserved as long as there is no external energy loss due to friction or air resistance. This is known as the principle of conservation of energy, which states that energy cannot be created or destroyed, only transferred or transformed.
