Kinetic and Potential Energy rollercoaster
In summary, the conversation discusses a roller coaster ride that has been modeled as a series of straight lengths of track. The roller coaster's carriages are represented as a particle with a mass of 400kg that can navigate bends without any loss of speed. The speed of the roller coaster at two points, A and B, is provided and the conversation then delves into finding the work done against resistance forces and the magnitude of these forces. Ultimately, the conversation concludes with a realization about a calculation error due to a calculator being in the wrong unit of measurement.
Gregg
459
The diagram shows part of the track of aroller coaster ride, which has been modeled as numbner of straight lengths of track. The roller coaster's carriages are modeled as a particle of mass 400kg which can negotiate bends A, B, C and D without any loss of speed. The speed of the roller coaster as A is 3m/s and at B it is 10m/s.
(a) Show that the work done against the resistance forces as the roller coaster moves from A to B is approx 8610J and use this to find the magnitude of the resistance forces assuming that they are constant.
The diagram shows a roller coaster. The relevant piece of the picture is that A is at the top of a slope and B is it the bottom. The length of the hypotenuse of these triangle (i.e. the distance from A to B) is 20m, and the incline is 20 degrees.
Loss in PE = Gain in KE + Loss due to resistance
mgh = 1/2 mv^2 + R
400x9.81x20sin(20) - 18200 = R
This is not 8610J ?
What you've done seems to be correct, unless there is additional information you haven't supplied us.
What is the total energy (potential and kinetic) of the roller coaster at A? What is the potential and Kinetic energy of the roller coaster at B? The difference in the two should be the energy lost to friction.
I think you are forgetting to include the roller coaster's kinetic energy at A, and you have only considered its potential energy.
Nah, he noted it down poorly but calculated [itex]\Delta mgh[/itex] and [itex]\Delta 1/2 m v^2[/itex].
Oh god. My calculator was in radians. Sorry everyone.
Related to Kinetic and Potential Energy rollercoaster
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is dependent on the mass and velocity of the object.
2. What is potential energy?
Potential energy is the energy an object possesses due to its position or state. It is dependent on the mass, height, and gravitational force acting on the object.
3. How do kinetic and potential energy relate to a rollercoaster?
A rollercoaster converts potential energy (from its initial height) into kinetic energy (as it moves down the track) and back again as it goes through loops and hills. The higher the initial height of the rollercoaster, the more potential energy it has, and the faster it will move due to the conversion to kinetic energy.
4. How does the design of a rollercoaster affect its kinetic and potential energy?
The design of a rollercoaster, including the height and shape of its hills and loops, can greatly affect the amount of potential and kinetic energy it possesses. A taller and steeper rollercoaster will have more potential energy and will be able to reach higher speeds due to the conversion to kinetic energy.
5. What safety measures are in place to ensure the proper balance of kinetic and potential energy in a rollercoaster?
Rollercoasters undergo rigorous safety testing and are designed with specific calculations to ensure that the balance between kinetic and potential energy is maintained. Additionally, safety features such as brakes and restraints are in place to control the speed and movement of the rollercoaster. Regular maintenance and inspections also help to ensure the proper balance of energy in a rollercoaster.
9K
