Kinetic Energy After Some Time Has Elapsed
In summary, a 5 kg ball is dropped from a height of 10 meters with a velocity of 14m/s. Using the equation KE=1/2mv^2, the kinetic energy is found to be 490 J. To find the kinetic energy after 1 second has elapsed, the acceleration due to gravity of 9.81m/s^2 is used to calculate the velocity. The resulting velocity can then be used to find the new kinetic energy.
quido
A balla of mass 5 kg is dropped from a height of 10 meters. What is the kinetic energy after 1 second has elapsed?First i found the velocity using this equation V^2=2gh = 14m/s
Then I used this equation to find Kinetic Energy KE=1/2mv^2 and got this 490 J.
But i don't know how to find KE after 1 second elapsed. Can anyone help me?
Hint: What's the acceleration due to gravity?
That's the all information I have.
The acceleration due to gravity is a constant. Check your book. (Hint: It's used in that equation you posted earlier.)
oh right. You mean 9.81m/s^2.
I used that to find Velocity? Was it wrong ?
Yes, that's what I mean. Now use it to find velocity after 1 second.
Oh thanks a lot.
FAQ: Kinetic Energy After Some Time Has Elapsed
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion.
How is kinetic energy calculated?
Kinetic energy is calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
How does kinetic energy change after some time has elapsed?
Kinetic energy can change after some time has elapsed if there is a change in the object's mass or velocity. If the object's mass increases or its velocity decreases, its kinetic energy will decrease. Conversely, if the object's mass decreases or its velocity increases, its kinetic energy will increase.
What factors affect the amount of kinetic energy an object has?
The amount of kinetic energy an object has is affected by its mass and velocity. Objects with larger mass or higher velocity will have more kinetic energy.
What is the relationship between kinetic energy and potential energy?
Kinetic energy and potential energy are two forms of energy that are interrelated. Kinetic energy is the energy of motion, while potential energy is the energy an object has due to its position or state. As an object gains kinetic energy, it loses potential energy, and vice versa.
