Kinetic Energy and Work: Ramp With Friction
The discussion focuses on calculating the coefficient of kinetic friction for a mass sliding down an inclined ramp with friction. The initial energy of the mass is determined using kinetic and potential energy formulas, factoring in the distances along the incline and level surfaces. The work done on the block is analyzed in two segments, leading to a derived formula for kinetic friction. Participants clarify the steps involved in the calculations, ensuring accuracy in the algebraic process. The thread emphasizes the importance of understanding energy conservation and work in friction scenarios.
CaptFormal
When mass M is at the position shown, it is sliding down the inclined part of a slide at a speed of 2.15 m/s. The mass stops a distance S2 = 2.5 m along the level part of the slide. The distance S1 = 1.22 m and the angle θ = 32.70°. Calculate the coefficient of kinetic friction for the mass on the surface.
Not quite sure how to start on this one. Any help will be appreciated. Thanks.Captformal
First, find the energy of the mass in its initial position.
E = K+U = \frac{1}{2}mv_{0}^{2} + mgS_{1}\sin(\theta)
Now note that the block has lost all of its energy once it reaches S_{2}.
E + W_{other} = 0 \iff W_{other} = -E
The work done on the block has to be described in 2 parts: one along the path S_{1} and another along the path S_{2}. If you draw a free body diagram, you'll find that:
W_{1} = [mg\cos(\theta)-u_{k}mg\sin(\theta) ]S_{1}
W_{2} = -u_{k}mgS_{2}
After going through an algebraic mess, you'll find:
u_{k} = \frac{ E + mg\cos(\theta)S_{1} }{mgS_{2} + mg\sin(\theta)S_{1} }
Hopefully I didn't make a mistake in there somewhere.
Thanks Vykan12. That helped out a lot.
  • · Replies 32 ·
  • · Replies 33 ·
