Kinetic energy fusion of protons
In summary: E9) (q1q2) / (2r) final kinetic energy = (1/2) m v^2 for the daughter nucleus, and hν for the photonIn summary, fusion reactions involve the joining of two atoms' nuclei to form a new element, resulting in a conversion of rest energy to kinetic energy. This process is crucial in the sun, where hydrogen is converted to helium. In such reactions, electrons are not involved and the focus is on the nuclei. The total kinetic energy of the
mshah3
38
In a fusion reaction, the nuclei of two atoms join to form a single atom of a different element. In such a reaction, a fraction of the rest energy of the original atoms is converted to kinetic energy of the reaction products. A fusion reaction that occurs in the Sun converts hydrogen to helium. Since electrons are not involved in the reaction, we focus on the nuclei.
The deuterium nucleus starts out with a kinetic energy of 6.2e-14 joules, and the proton starts out with a kinetic energy of 1.23e-13 joules. The radius of a proton is 0.9e-15 m; assume that if the particles touch, the distance between their centers will be twice that. What will be the total kinetic energy of both particles an instant before they touch?
What is the kinetic energy of the reaction products (helium nucleus plus photon)?
joules
C: Gain of kinetic energy:
What was the gain of kinetic energy in this reaction? (The products have more kinetic energy than the original particles did when they were far apart. How much more?)
joules
D: Fusion as energy source
Kinetic energy can be used to drive motors and do other useful things. If a mole of hydrogen and a mole of deuterium underwent this fusion reaction, how much kinetic energy would be generated?
joules
(For comparison, around 1e6 joules are obtained from burning a mole of gasoline.)
Uel = (9E9) (q1q2) / ( r)
used formula: Uel = (9E9) (q1q2) / ( r)
as my formula for kinetic energy
was incorrect
gives potential energy.
use conservation of energy.
initial potential energy + initial kinetic energy = final potential energy + final kinetic energy.
I think you can assume that initial r is infinite... so initial potential energy = 0.
I would like to clarify that the formula you have used, Uel = (9E9) (q1q2) / ( r), is not the correct formula for kinetic energy. The correct formula for kinetic energy is KE = 1/2mv^2, where m is the mass of the particle and v is its velocity.
In the given scenario, the total kinetic energy of both particles an instant before they touch would be the sum of their individual kinetic energies. This can be calculated by using the formula KE = 1/2mv^2, where m is the mass of the particle and v is its velocity.
For the deuterium nucleus, m = 2.0141 u (atomic mass units) and v = 6.2e-14 joules (given in the problem). Converting the mass to kilograms and using the conversion factor 1 u = 1.66054e-27 kg, we get m = 3.3436e-27 kg. Plugging these values into the formula, we get KE = 1/2(3.3436e-27 kg)(6.2e-14 m/s)^2 = 6.155e-41 joules.
Similarly, for the proton, m = 1.0073 u and v = 1.23e-13 joules. Converting the mass to kilograms, we get m = 1.6735e-27 kg. Plugging these values into the formula, we get KE = 1/2(1.6735e-27 kg)(1.23e-13 m/s)^2 = 1.282e-41 joules.
Therefore, the total kinetic energy of both particles an instant before they touch is 6.155e-41 + 1.282e-41 = 7.437e-41 joules.
Moving on to the kinetic energy of the reaction products (helium nucleus plus photon), we need to consider the conservation of energy. In a fusion reaction, the total energy of the reactants (deuterium and proton) should be equal to the total energy of the products (helium nucleus and photon). Therefore, the kinetic energy of the reaction products would be equal to the total kinetic energy of the reactants, which is 7.437e-41 joules.
Finally, to calculate the gain of kinetic energy in
Related to Kinetic energy fusion of protons
1. What is kinetic energy fusion of protons?
Kinetic energy fusion of protons is a process in which two or more protons collide at high speeds and fuse together, releasing a large amount of energy in the form of heat and light.
2. How is kinetic energy fusion of protons different from nuclear fusion?
Kinetic energy fusion of protons is a type of nuclear fusion, where protons are fused together, while nuclear fusion refers to any process in which two or more atomic nuclei combine to form a heavier nucleus.
3. What are the potential applications of kinetic energy fusion of protons?
The potential applications of kinetic energy fusion of protons include energy production, medical isotope production, and research into fusion energy as a potential replacement for traditional fossil fuels.
4. How is kinetic energy fusion of protons achieved in a controlled environment?
In order to achieve kinetic energy fusion of protons in a controlled environment, high temperatures and pressures are required to overcome the repulsive forces between the positively charged protons. This can be achieved using powerful lasers or magnetic fields.
5. What are the challenges in harnessing the energy from kinetic energy fusion of protons?
The main challenges in harnessing the energy from kinetic energy fusion of protons include the high temperatures and pressures required, as well as the difficulty in confining and controlling the fusion reaction. Additionally, the cost and technological barriers involved in building and maintaining a fusion reactor are significant hurdles to overcome.
