Kinetic energy in frames of reference
In summary, the question asks why when two objects have the same initial velocity and one accelerates to twice the velocity, the gain in kinetic energy with respect to Earth and the other object are different, but the work done is constant. The answer lies in the fact that the distance traveled in the stationary frame is different, resulting in a larger work done and kinetic energy gain.
daveed
138
i was just reading, and i saw this question, and i don't know how to explain it...
how can you describe why when two things go at a velocity v, and one of them accelerates to 2v, the KE gain w/ respect to the Earth and the other object are different, but the work done is constant?
i just don't know how to explain this... it should not be so difficult, no?
The work, Fx (assuming constant acceleration), isn't constant. The force is the same in both frames, but the distance isn't.
[tex]x=\int v~dt[/tex]
Moving frame:
[tex]v=\int a~dt=at[/tex]
[tex]x=\frac{1}{2}at^2[/tex]
Stationary frame:
[tex]v=v_0+\int a~dt=v_0+at[/tex]
[tex]x=v_0t+\frac{1}{2}at^2[/tex]
In your example, this leads to work that's three times larger in the stationary frame, just like the change of kinetic energy.
Kinetic energy is defined as the energy an object possesses due to its motion. In the context of frames of reference, it is important to understand that kinetic energy is a relative quantity and is dependent on the frame of reference in which it is measured. This means that the kinetic energy of an object will appear differently to observers in different frames of reference.
In the scenario described, two objects are initially moving at a velocity v and one of them accelerates to a velocity of 2v. This means that the change in kinetic energy for this object is greater than the other object, as it has a higher velocity. However, this does not mean that the work done on both objects is different.
Work is defined as the transfer of energy from one object to another. In this case, the work done on both objects is constant because the same amount of energy is being transferred from the accelerating object to the other object, regardless of their different velocities. This is because the work done is dependent on the force applied, and not just the velocity of the object.
To explain why the kinetic energy gain is different for the two objects, we must consider the concept of relative motion. From the perspective of the Earth, the initial velocity of both objects was v. However, when one object accelerates, its velocity relative to the other object changes from v to 2v. This change in relative velocity results in a greater change in kinetic energy for the object that accelerates.
In conclusion, the difference in kinetic energy gain for the two objects can be explained by considering the concept of relative motion and the frame of reference in which the kinetic energy is measured. The work done, on the other hand, remains constant as it is dependent on the force applied, not just the velocity of the object.
FAQ: Kinetic energy in frames of reference
What is kinetic energy in frames of reference?
Kinetic energy in frames of reference refers to the energy that an object possesses due to its motion relative to a particular frame of reference. It is a measure of the amount of work that an object can do because of its motion.
How is kinetic energy calculated in different frames of reference?
Kinetic energy can be calculated in different frames of reference using the same formula: KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity relative to the frame of reference. However, the values of mass and velocity may differ in different frames of reference, resulting in different values of kinetic energy.
Can kinetic energy be negative in some frames of reference?
Yes, kinetic energy can be negative in some frames of reference. This typically occurs when an object is moving in the opposite direction to the chosen frame of reference, resulting in a negative velocity. In this case, the kinetic energy would also be negative, indicating that the object is losing energy due to its motion.
How does kinetic energy in frames of reference relate to the principle of relativity?
The principle of relativity states that the laws of physics are the same in all inertial frames of reference. This means that the value of kinetic energy in different frames of reference may vary, but the laws governing its calculation and usage remain the same.
What are some real-world applications of understanding kinetic energy in frames of reference?
Understanding kinetic energy in frames of reference is crucial in various fields, such as mechanics, engineering, and physics. It helps in predicting the behavior of moving objects, designing efficient machines and structures, and understanding the motion of particles in different systems, such as in thermodynamics and fluid dynamics.
