Kinetic Energy / Momentum Problem
The discussion focuses on a physics problem involving two railway cars colliding and the resulting change in kinetic energy. Participants explore the conservation of momentum and kinetic energy equations to demonstrate that the change in kinetic energy is maximized when the cars couple together, leading to equal final velocities (v'1 = v'2). Various attempts are made to manipulate the equations and derive the necessary relationships, with one participant successfully showing that substituting values leads to the conclusion that v'1 equals v'2. The conversation highlights the importance of following initial guidance and systematically applying the equations to reach the solution. Ultimately, the problem is resolved through collaboration and persistence in solving the equations.
dimeking
Two Railway cars, m1 and m2, are moving along a track with velocities v1 and v2, respectively. The cars collide, and after the collision the velocities are v'1 and v'2. Show that the change in kinetic energy, K' - K, will be maximum if the cars couple together.
Hint: Set d(K' - K)/dv'1 = 0 and show that v'1 = v'2.
Conservation of linear momentum: m1v1 + m2v2 = m1v'1 + m2v'2.
Kinetic energy K = 0.5mv^2
Difference in kinetic energy: K' - K = 0.5m1v1^2 + 0.5m2v2^2 - 0.5m1v'1^2 - 0.5m2v'2^2.
I solved the conservation of momentum equation for v1 and substituted that into the K' - K equation. This yields v'2 = v2.
I then solved the conservation of momentum equation for v2 and substituted that into the K' - K equation. I got v'1 = (m1v1 - m2v'2) / (m1 - m2).
Since the hint mentions finding the derivative of the kinetic energy difference with respect to v'_{1}, you should find the value of v'_{2} in terms of v'_{1}. Substitute that into the energy difference and then use the hint (Note that v_{1} and v_{2} are constant in that expression).
Thank you for responding, Pi-Bond. If I solve the momentum equation for v2-prime in terms of the other v's, and then substitute this into the energy equation, the energy equation wil be in terms of v1-prime, v1, and v2. I will not be able to show that v1-prime equals v2-prime.
If you do that, what value for v'_{1} do you get?
Your two equations are sufficient; you can get the result by using the conservation equation to find an expression m_{1} v_{1}, which can be substituted into your second equation along with your first equation.
I still cannot solve this.
When I solve the conservation of momentum equation for m2v'2 and then substitute this into the K' - K equation and then take its derivative and set it equal to zero, I get v'1 = 0.5v'2.
When I solve the conservation of momentum equation for m1v1 and then substitute this into the K' - K equation and then take its derivative and set it equal to zero, I get v'1 = 0.5v1.
Finally, when I solve the conservation of momentum equation for m2v2 and then substitute this into the K' - K equation and then take its derivative and set it equal to zero, I get v'1 = 0.5v2.
You got the equations:
v'_{2}=v_{2}
v'_{1}=\frac{m_{1} v_{1} - m_{2} v'_{2} }{m_{1}-m_{2}}
From conservation of momentum,
m_{1} v_{1} = m_{1} v'_{1}+ m_{2} v'_{2} - m_{2} v_{2}
Substitute that above to get:
m_{1} v'_{1} - m_{2} v'_{1} = m_{1} v'_{1}+ m_{2} v'_{2} - m_{2} v_{2} - m_{2} v'_{2}
Can you get the result now?
OK, I finally got it. It would have gone quicker if I had just followed the advice in your first post.
I solved the conservation of momentum equation for v'2, then substituted that into the kinetic energy equation, then set its derivative equal to zero and solved for v'1.
I then substituted this value for v'1 back into my equation for v'2 and showed that v'2 reduced to the same expression as v'1.
Pi-Bond, thank you for your help and patience.
  • · Replies 22 ·
