Kinetic energy of an alpha particle
haha0p1
46
A stationary U-238 nucleus decays be alpha emission generating a total kinetic energy T. What is the kinetic energy of alpha particle?
Ek=1/2mv²
Ek=Momentum²/2m
Kindly help me solve this question. The only thing so far that I know in this question is that energy is conserved and the momentum of Alpha particle will equal momentum of Thorium.
So what is your conservation of energy equation?
Btw, the momenta will be equal and opposite, not equal.
Likes vanhees71 and topsquark
T=1/2×4×Va²+1/2×mth×Vth²
T=2Va²+117×Vth²
√(T-2Va²)÷117=Vth
Hence, the statement 'slightly less than T' will be correct
Is this approach to the answer correct ?
haha0p1 said:
T=1/2×4×Va²+1/2×m×Vth²
T=2Va²+117×Vth²
√(T-2Va²)÷117=Vth
You will need to tell me what all those symbols mean if you want me to check it.
Likes vanhees71, haha0p1 and topsquark
T=Total Kinetic energy
Va=Velocity of Alpha particle
Vth=Velocity of Thorium particle
ma=Mass of alpha particle
mth=Mass of Thorium particle
These are the symbols for the above equation.
T=2Va²+117×Vth²
√(T-2Va²)÷117=Vth
Your approach is not correct because you did not use the fact that the momenta are equal in agnitude and opposite in direction. Furthermore, your conclusion does not follow from the work that you have shown. The last equation is an expression for the speed of the thorium. You have not explained your reasoning in terms of this equation that leads to your conclusion
Can you please explain to me how we got the right answer.?
I would write separate equations for the kinetic energy of the thorium and the alpha. I would then use the momentum conservation equation to relate the alpha speed to the thorium speed. Do that first and maybe you will see where to go from there.
There are two equations for kinetic energy i.e, Ek= p²÷2m & 1/2mv². Which one should i use from these two for finding separate kinetic energies for the alpha particle and thorium
Use the first form and write the total kinetic energy. It should be easier to see what’s going on.
Solving the question through your method:
T=(Pth²÷2×234)+(pa²÷2×4)
=((234×v1)²÷468)+((4×v2)²÷8)
= 117v1²+2v2²
What should I do next. Also note that I am facing the problem that i was facing from the beginning i.e: The value of V1 (velocity of Thorium) and V2 (velocity of alpha particle) is still there.
= 117v1²+2v2²
You are still not using conservation of energy. What other energy change occurs in the reaction?
I am not getting your point. As far as I know, conservation of energy remains same at the end of the reaction. So T will equal the energy of alpha particle+energy of thorium. I am making the equation based upon this concept. Am I missing out something?
Where did that KE come from?
At first the nucleus was stationary. So, the energy T is in form of chemical energy. After the emission of Alpha particle and thorium, the energy is converting to mostly kinetic energy of the particle.
Not chemical.
haruspex said:
Not chemical.
The kinetic energy came from the internal energy of the nucleus?
haha0p1 said:
Then internal energy?
Try nuclear.
But I am guilty of not checking exactly what the question asked for. It is possible to calculate T's value from the masses of all the reagents involved, but you don't need to.
Let's start again .
Working wholly symbolically (no plugging in numbers for the masses!), write the expressions for:
  • momentum of alpha particle
  • momentum of thorium atom
  • KE of alpha particle
  • KE of thorium atom
in terms of their masses and velocities.
Then write the equation relating the momenta and consider the ratio of the KEs, not their sum.
Likes PeroK
haruspex said:
Try nuclear.
Let's start again .
Momentum of alpha particle=m×v
Momentum of thorium atom=m1×v1
KE of alpha particle = 1/2 mv²
KE of Thorium atom = 1/2×m1×v1²
Since momentum is conserved:
Momentum of alpha particle=Momentum of Thorium atom
1/2mv=1/2×m1×v1²
I am stuck here.
1/2mv=1/2×m1×v1²
Try that one again.
Then use the momentum equation to eliminate v1 from the expression for the KE of Thorium atom.
Likes haha0p1
haruspex said:
Try that one again.
I am unable to understand how we can use momentum equation to eliminate this one. Can you please explain.
Write the momentum equation correctly, then use it to express v1 in terms of the other variables. You can then use that to replace v1 in the energy expression.
Likes haha0p1
mv=m1v1
mv÷m1=v1
T=k.e of alpha+k.e of Th =1/2×4×v²+1/2×m1×(m×v)÷m1
T-E.K of th = E.K of alpha
T-1/2 m1×((mv)÷m1)= E.K of alpha
T-1/2×234×((4×v)÷234)=E.K of alpha
T-2v=E.K of alpha
I have reached the answer T-2v. Is it right.?
That can't be right as the dimensions of the ##2v## are not right. The expression must have dimensions of energy.
There are two things here. First, is simply manipulating equations to get to the answer. The second is understanding what each equation is saying and using that to guide what you are doing.
The key point here is we have a single particle decaying into two particles. The first partcle, the Thorium atom, is much more massive than the second, the alpha particle. I think you should number both particles. Let ##m_1## be the mass of the alpha particle amd ##m_2## be the mass of the Thorium atom. Conservation of momentum gives you:$$m_1v_1 = m_2v_2$$Where ##v_1, v_2## are the magnitudes of the velocities of the two particles.
Given that ##m_1 \ll m_2##, what does that tell you about ##v_1## and ##v_2##?
Likes haha0p1 and malawi_glenn
= 117v1²+2v2²
You have reached the equation for the total energy that can be aritten as $$T=\frac{P_{Th}^2}{2m_{Th}}+\frac{P_{\alpha}^2}{2m_{\alpha}}.$$The problem is not asking you to find the kinetic energy of the alpha particle. It is giving you 4 choices. You can find the correct one by examining the equation above and using momentum conservation that says ##P_{Th}^2=P_{\alpha}^2.## If you cannot do this simply by looking at the equation, substitute ##m_{Th}=234~##u and ##m_{\alpha}=4~##u in the equation and figure out whether the second term is closer to ##T/2## than ##T##, i.e. if the answer one of (A, B) or one of (C, D). Then refine your choice.
Likes haha0p1
To try to progress this, the conclusion is that ##v_1 \gg v_2##. I.e. if a small mass and a large mass have the same magnitude of momentum, then the small mass must have the greater speed.
This is something that you should try to understand and remember. You can, of course, encapsulate this idea in an equation, but you should be able to picture the Thorium atom moving slowly away in one direction, while the alpha particle flies off much faster in the opposite direction.
The next step is to think about KE. What's the relationship between ##T_1## and ##T_2##?
