Kinetic energy of gases in stars
In summary, we use the one dimensional kinetic energy E=1/2kT to calculate the temperature of the star's chromosphere. The sun is the only star whose chromosphere is observationally accessible. We are still trying to figure out its heating mechanism.
Piano man
75
Hi,
I have a conceptual and mathematical question about gases in stars.
The information we have from stars is due to the motion of particles in one dimension: along our line of sight.
We assume that this motion is isotropic and that regardless of where on the star we look, we'll get the same motion.
So, when calculating the temperature of the star's chromosphere, do we use the one dimensional kinetic energy E=1/2kT, the three-dimensional kinetic energy E=3/2kT or the average kinetic energy E=kT to equate to 1/2mv^2, where v is the one dimensional velocity?
Astronomy news on Phys.org
The sun is the only star whose chromosphere is observationally accessible. We are still trying to figure out its heating mechanism. The photosphere temperature is relatively simple to calculate. The most widely used method is based on Wien's law, which only requires measurement of the peak emission frequency. This can be done both with the sun and any star bright enough for spectroscopic measurements. Another, more accurate, method relies on the strength of different absorption lines in the spectrum.
Piano man said:
Hi,
Could you elaborate on this? I'm not sure I understand it correctly.
Sort of the middle one, E=kT, but I wouldn't call that "average kinetic energy" because I don't know what you mean by that (the average kinetic energy is the 3D kinetic energy, 3/2kT). First I should point out that we must be clear what v is-- it isn't actually the "one dimensional velocity," because if we have a T, we have many different velocities there. So v either has to be the standard deviation of the one-dimensional velocity, or more commonly, it is the "Doppler width" of the line in v units, which is something different. What you actually do is observe the line broadening, which gives you the spread in velocity along the line of sight (let's use the "Doppler width" meaning for v). You then assume the velocities are distributed isotropically and like a Maxwellian (assumptions we have good reason to expect in high densities), and reverse engineer what the T has to be to produce the spread in line-of-sight velocities that you see. It comes out the same as equating 1/2mv^2 to kT, but that's just how it comes out-- I don't see any way to assert that in advance, because neither 1/2mv^2 nor kT have any particular physical meaning in this situation.
Getting back to the tricky difference between what we call the "Doppler width" of a line, and what is the "standard deviation" of the line-- if we define v to be the standard deviation (the root-mean-square line-of-sight velocity), then it would be appropriate to call 1/2mv^2 to be the kinetic energy in the line-of-sight direction, and equate it with 1/2kT, which is the energy at T in that same direction. But that v isn't what is meant by the Doppler width v, which is the v appearing directly in the Gaussian shape of the line. The latter v, the Doppler width, is larger, so that v would use the expression 1/4mv^2 as the kinetic energy from the component of motion along that direction. You'd equate that to 1/2kT, and get the same result as what we were talking about above.
This is a great question! When it comes to calculating the temperature of a star's chromosphere, we actually use the three-dimensional kinetic energy equation, E=3/2kT. This is because the particles in a star's atmosphere are not limited to just one dimension, they have motion in all three dimensions. This means that the average kinetic energy of the particles will be higher than just in one dimension. Using the one-dimensional kinetic energy equation would underestimate the actual temperature of the chromosphere.
However, it is important to note that in certain cases, such as in very dense and hot regions of a star, we may need to use the average kinetic energy equation, E=kT, to account for the varying velocities and energies of the particles. This is because in these extreme conditions, the particles may not behave in a perfectly isotropic manner and may have different velocities and energies in different directions.
Overall, the three-dimensional kinetic energy equation is the most accurate and commonly used equation for calculating the temperature of a star's chromosphere. I hope this helps clarify any confusion and please let me know if you have any further questions.
Related to Kinetic energy of gases in stars
1. What is kinetic energy in the context of stars?
Kinetic energy in stars refers to the energy associated with the movement of gas particles within a star. As gas particles move, they collide with each other and with the walls of the star, creating heat and releasing energy. This energy is known as kinetic energy.
2. How is kinetic energy related to the temperature of a star?
The temperature of a star is directly related to the average kinetic energy of the gas particles within it. As the temperature of a star increases, the gas particles move faster and have higher kinetic energy. This is because temperature is a measure of the average kinetic energy of a substance.
3. How does the kinetic energy of gases affect the luminosity of a star?
The kinetic energy of gases in a star is one of the main factors that determines its luminosity. As gas particles move and collide with each other, they release energy in the form of light. Therefore, stars with higher kinetic energy will emit more light and have a higher luminosity.
4. Can the kinetic energy of gases in stars be measured?
Yes, the kinetic energy of gases in stars can be measured using various techniques and instruments. For example, scientists can use spectroscopy to study the movement of gas particles and calculate their kinetic energy. They can also measure the temperature and luminosity of a star, which are indicators of its kinetic energy.
5. How does the kinetic energy of gases change over the lifespan of a star?
The kinetic energy of gases in a star changes over its lifespan. In the early stages, when a star is still forming, gas particles have high kinetic energy due to the intense gravitational forces and high temperatures. As a star ages and starts to run out of fuel, the kinetic energy of its gases decreases, leading to a decrease in its luminosity.
  • Astronomy and Astrophysics
