Kinetic energy of space probe launched from planet
In summary: It should be 7.0x10^6 m, not 4.0x10^6 m. So the correct equation is:K2 = K1 + GMm((1/r2)-(1/r1))which gives the correct answer of 21652500 J.
1MileCrash
1,342
41
Zero, a hypothetical planet, has a mass of 3.0 x 10^23 kg, a radius of 3.0 x 10^6 m, and no atmosphere. A 17 kg space probe is to be launched vertically from its surface.
If the probe is launched with an initial kinetic energy of 5.0 x 10^7 J, what will be its kinetic energy when it is 4.0 x 10^6 m from the center of Zero?
I figure that mechanical energy is conserved, and so
K1 + U1 = K2 + U2
With U given by GmM/r.
So
[itex]K_{2} = K_{1} + GmM(r^{-1}_{2} - r^{-1}_{1})[/itex]
With r1 = 3.0x10^6, and r2 = 3.0x10^6 + 4.0x10^6 = 7.0x10^6
Which gives me the negative value -14794285.71 for K2.
I have no idea what is wrong with the equation I'm using.
Any ideas?
gravitational potential energy is negative
also I think that your r2 is a bit too big
Yes, so
K1 - (GmM/r1) = K2 - (GmM/r2)
And
K2 = K1 - (GmM/r1) + (GmM/r2)
K2 = K1 + (GmM/r2) - (GmM/r1)
Which is what I used..
1MileCrash said:
Yes, so
And
I did
K2 = K1 - U1 + U2
K2 = K1 -(U1 - U2)
K2 = K1 -GmM((1/r1) - (1/r2))
and got 21652500 J
I also got the same number when I used your method
I think the problem is your value for r2
I would like to point out that the initial kinetic energy of the space probe does not depend solely on the mass and radius of the planet, but also on the velocity at which it is launched. Therefore, without knowing the initial velocity of the probe, it is not possible to accurately calculate its kinetic energy at a specific distance from the center of the planet.
However, assuming that the probe is launched with a velocity that allows it to escape the gravitational pull of Zero, the equation for conservation of mechanical energy would be valid. In this case, the initial kinetic energy of the probe would be equal to the gravitational potential energy at the surface of the planet, which can be calculated using the given mass and radius of Zero. The final kinetic energy at a distance of 4.0 x 10^6 m from the center of Zero can then be calculated using the same equation, as you have done.
It is possible that the negative value you obtained for K2 is due to a mistake in the calculation or a sign error. It would be helpful to double check your calculations and make sure that you are using the correct units. Also, keep in mind that the final kinetic energy may be negative if the probe is slowing down due to the gravitational pull of Zero.
Related to Kinetic energy of space probe launched from planet
1. What is kinetic energy and how is it related to a space probe launched from a planet?
Kinetic energy is the energy an object possesses due to its motion. When a space probe is launched from a planet, it gains kinetic energy as it moves away from the planet's gravitational pull.
2. How is the kinetic energy of a space probe calculated?
The kinetic energy of a space probe can be calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the probe and v is its velocity.
3. Does the kinetic energy of a space probe change as it travels through space?
Yes, the kinetic energy of a space probe changes as it travels through space. As the probe moves farther away from the planet, its velocity decreases and therefore its kinetic energy decreases as well.
4. Can the kinetic energy of a space probe be used to maneuver it in space?
Yes, the kinetic energy of a space probe can be used to maneuver it in space. By adjusting the probe's velocity and direction, the amount of kinetic energy can be controlled, allowing for changes in its trajectory.
5. How important is the kinetic energy of a space probe in its mission?
The kinetic energy of a space probe is crucial in its mission as it determines the probe's speed and ability to reach its destination. Without enough kinetic energy, the probe may not be able to travel far enough or fast enough to complete its mission.
