Kinetic energy of the emitted electrons
In summary, when the frequency of light incident on a metallic plate is doubled, the kinetic energy of the emitted photoelectrons will be more than twice the initial kinetic energy due to the fixed cost of the work function. This can be understood through the analogy of hiring a plumber where the fixed cost is shared between multiple people.
xiphoid
57
When the frequency of light incident on a metallic plate is doubled, the K.E. of the emitted photoelectrons will be?
The answer should be either doubled or increased but more than double of the previous kinetic energy
λ= h/ √2mK.E.
therefore, 1/v= h/c*√2mK.E.
K.E. of photoelectron = (KE of incident photon) - (Work Function of Metal).
Since you doubled the energy of incident photon, it will no doubt increase the KE of photoelectron, but the extra energy will be purely dedicated in doing so, unlike before doubling the energy, in which some of the energy was required to free electron from the metal.
So, the new KE will be more than double the initial KE.
Let's use this equation and say that this is the starting point.
Now, you have doubled the incident photon's energy, which is one term on the right side. However, the second term, the work function, is still the same. This is the crux of the problem.
K.E. of photoelectron 1 = (KE of incident photon 1) - (Work Function of Metal).
K.E. of photoelectron 2 = (KE of incident photon 2) - (Work Function of Metal).
Now, rewriting this energy in terms of the energy of incident photon,
K.E. of photoelectron 2 = 2*(KE of incident photon 1) - (Work Function of Metal).
Difference of the two energies = KE of incident photon 1
Question: How did I get this relation? Simple enough, but just saves me some typing
So, the energy of the second photoelectron EXCEEDS that of the earlier one by a magnitude equal to the KE of incident photon 1.
BUT, KE of incident Photon 1 is MORE than the KE of photoelectron 1 (by first equation.)
So, yes, answer is more than twice of the initial photoelectron.
Intuition
Think of the problem this way - You have to hire a plumber. You have to pay for the services and his transportation cost. BUT, if your neighbor decides to have the plumbing done too, the two of you will not pay the transportation cost twice.
So, effectively, the cost per person is LESS than that if only one person would have asked for plumber.
It's really a fixed cost, variable cost problem which we learned in our linear equation days.
Likewise, the work function has to be paid off only once, for the electron to surface. It has got nothing to do with the incident energy of the photon.
FAQ: Kinetic energy of the emitted electrons
What is kinetic energy of the emitted electrons?
Kinetic energy of the emitted electrons refers to the energy possessed by the electrons as they are emitted from a material, typically due to the absorption of some form of energy such as light or heat.
How is the kinetic energy of the emitted electrons calculated?
The kinetic energy of emitted electrons can be calculated using the equation KE = 1/2 * m * v^2, where m is the mass of the electron and v is its velocity.
What factors affect the kinetic energy of the emitted electrons?
The kinetic energy of the emitted electrons can be affected by the intensity and wavelength of the incoming radiation, the properties of the material (such as its work function and electron density), and the angle at which the electrons are emitted.
What is the significance of the kinetic energy of the emitted electrons?
The kinetic energy of emitted electrons is an important factor in understanding the properties of materials and their interactions with energy. It can also provide insights into the behavior of electrons within a material and can be used in various applications such as photoelectron spectroscopy.
How is the kinetic energy of the emitted electrons used in practical applications?
The kinetic energy of the emitted electrons is used in various practical applications such as solar panels, photocathode electron guns, and photoelectron spectroscopy. It can also be used to study the properties of materials and their electronic structures.
