Kinetic Energy of two positive charges flying apart
In summary, when calculating the kinetic energy of a positive charge moving in the direction of an electric field produced by another positive charge, the assumption is usually made that the source charge remains stationary. However, if both charges are allowed to move, the original potential energy is shared between the two charges based on their masses and positions. This can be solved using Lagrangian mechanics or by simplifying the problem to a one-body system.
UMath1
361
Usually when we calculate the kinetic energy acquired by a positive charge as it moves in the direction of the electric field produced by another positive charge, we assume that the source charge remains stationary and so the loss in potential energy for the moving charge is equal to its gain in kinetic energy.
But what if both charges are allowed to move? Is the original potential energy shared between the two charges? Would you use half of the original potential energy for each of the two charges?
In the lab frame:
You can work out the potential energy between the initial and final positions - this will tell you the total change in kinetic energy.
The symmetry dictates how the kinetic energy is shared.
You can also work the problem by brute force using Lagrangian mechanics.
A lot depends on what, exactly, you are trying to calculate.
It's not hard with two charges. If they are identical charges then you can just accelerate both of them by the same amount. If not, you can convert it into a 1 body problem using the reduced mass.
For N particles, positions ##\vec r_i## Newton's second law for the jth particle is $$k\sum_{i\neq j}^N \frac{q_iq_j}{|\vec r_j-\vec r_i|^3}(\vec r_j-\vec r_i) = m_j\frac{d^2}{dt^2}(\vec r_j-\vec r_i)$$
... the result is a system of N differential equations which you can solve for each ##r_i(t)## by the usual methods.
For the case of two identical particles, ##q_1=q_2=q## and ##m_1=m_2=m## this simplifies to:
$$\frac{kq^2}{|\vec r_2-\vec r_1|^3}(\vec r_2-\vec r_1) = m\frac{d^2}{dt^2}(\vec r_2-\vec r_1)\\
\frac{kq^2}{|\vec r_1-\vec r_2|^3}(\vec r_1-\vec r_2) = m\frac{d^2}{dt^2}(\vec r_1-\vec r_2)\\
\vec r_1(0)=\vec r_{01}, \vec r_2(0)=\vec r_{02}, \frac{d}{dt} \vec r_1(0) = \frac{d}{dt} \vec r_2(0) = 0$$
It is usually easier to change coordinates so that one axis (usually z) lies along ##\vec r_2-\vec r_1## with the origin half way between the particles.
This way the particles start at ##\pm z_0## given by ##z_0 = \frac{1}{2}|\vec r_1-\vec r_2|##.
The equations become:
$$\frac{kq^2}{(z_2-z_1)^2}\hat k = m\frac{d^2z_2}{dt^2}\hat k\\
\frac{kq^2}{(z_2-z_1)^2}\hat k = -m\frac{d^2z_1}{dt^2}\hat k\\
z_1(0)=-z_0, z_2(0)=z_0, \dot z_1=\dot z_2 = 0$$ ... something like that.
But if the particles start out stationary at ##\pm z_0## at some time, and they are later at ##\pm z_1## so that ##z_1>z_0##, then, ceteris paribus, we can work out their velocities by conservation of energy:
$$v^2 = \frac{kq^2}{m}\left(\frac{1}{z_0}-\frac{1}{z_1}\right)\\ \vec v_2=v\hat k = -\vec v_1$$
FAQ: Kinetic Energy of two positive charges flying apart
1. What is the definition of kinetic energy?
Kinetic energy is the energy an object possesses due to its motion.
2. How is kinetic energy calculated?
Kinetic energy is calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
3. How does the kinetic energy of two positive charges flying apart change?
The kinetic energy of two positive charges flying apart increases as they move further apart due to the increase in their velocity.
4. What factors affect the kinetic energy of two positive charges flying apart?
The kinetic energy of two positive charges flying apart is affected by the mass and velocity of the charges, as well as the distance between them.
5. How is the concept of kinetic energy applied in real life?
Kinetic energy is a fundamental concept in physics that is applied in various fields such as engineering, sports, and transportation. For example, the kinetic energy of a moving vehicle is used to power it, and the kinetic energy of a ball is used in sports like basketball and soccer.
