Kinetic Energy of two Rolling Objects on a Slope
In summary, the conversation discusses the problem of a hollow cylinder with a smaller solid cylinder inside it rolling down an incline. The total kinetic energy of the system is calculated using equations for translational and rotational kinetic energy for both cylinders. There is a discrepancy in the solution, with one person suggesting an extra term to account for the rotational motion of the smaller cylinder around the larger one.
interference
Hi everyone, not a homework problem, just something I was thinking about when I found in a book.
A hollow Cylinder is rolling down an incline of angle theta. Inside the cylinder is a smaller solid cylinder rolling freely inside it. (Refer to diagram)
Given an x coordinate from the top of the slope which the cylinders were released, and:
Large Cylinder has mass M, moment of inertia I, radius R
Small cylinder has mass m, moment of inertia i, radius r
(p.s. I labeled the small mass m wongly in the diagram!)
The small cylinder is allowed to roll freely in the large cylinder, and we call the angle it makes from vertical phi.
What is the Total Kinetic Energy of the system?
v=rw
K=(1/2)Iw^2 > where w is angular velocity
The Kinetic Energy for the Large Cylinder seems straightforward:
[tex]
K=\frac{1}{2}\left(M\dot{x}^2+\frac{I\dot{x}^2}{R^2}\right)
[/tex]
which is the translational KE and the rotational KE.
However, I am not sure about about the smaller cylinder. I believe there are 3 parts to its KE, namely the translational KE, the KE associated with it doing a circular motion on the rim of the large cylinder (I use the parallel axis theorem), and its own rotational KE.
[tex]
K=\frac{1}{2}\left(m\dot{x}^2+\left(i+m\left(R-r\right)^2\right)\dot{\phi}^2+\frac{i\dot{x}^2}{r^2}\right)
[/tex]
However, I am unsure about this because the small cylinder is also rotating somewhat around the large cylinder which is itself rolling down the slope.
Any advice or help is appreciated! Thank you!
the last term should be multiplied my R^2 / r^2.
we assume there is no slip at the contact between the 2 cyls. so the (translational) velocities of the points of contact between the 2 cyl is the same.
so R*w1 = r*w2
w2 = (R/r)*w1
this brings in the extra factor
the mistake you made was in assuming the same w for both the cylinders
so R*w1 = r*w2
w2 = (R/r)*w1
Hi,
I did know that the angular velocities for each cylinders are different
[tex]
v=R\omega_{M}=r\omega_{m}
[/tex], thus
[tex]
\omega_{m}=\frac{\dot{x}}{rR}R=\frac{\dot{x}}{r}
[/tex]
Which I have taken into account already in the last term which is the small cylinder's own rotational kinetic energy about its own axis.
Also, I found a solution which adds another term:
[tex]
m\dot{x}\dot{\phi}\left(R-r\right)\left(\frac{i}{mr^2}+cos\left(\phi+\theta\right)\right)
[/tex]
But I do not understand where that comes from. Can anyone please help shed some light?
FAQ: Kinetic Energy of two Rolling Objects on a Slope
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is calculated as one-half of the mass of the object multiplied by the square of its velocity.
How is kinetic energy related to rolling objects on a slope?
When two objects are rolling on a slope, their kinetic energy is a combination of their translational and rotational kinetic energy. The translational kinetic energy is due to the object's overall motion, while the rotational kinetic energy is due to its rotation about its center of mass.
How does the slope angle affect the kinetic energy of rolling objects?
The slope angle affects the kinetic energy of rolling objects by changing the potential energy of the objects. The steeper the slope, the more potential energy is converted into kinetic energy as the objects roll down the slope.
What is the relationship between the mass of the objects and their kinetic energy?
The kinetic energy of rolling objects is directly proportional to their mass. This means that objects with a greater mass will have a greater kinetic energy than objects with a lower mass, assuming they have the same velocity.
Can the kinetic energy of rolling objects be converted into other forms of energy?
Yes, the kinetic energy of rolling objects can be converted into other forms of energy, such as heat or sound, when the objects come to a stop. This is due to the friction and resistance between the objects and the surface they are rolling on.
