Kinetic energy physics exercise
In summary, the conversation discusses an exercise in which a ball is dropped through a slide and travels horizontally at the bottom. The ball's total energy remains constant and no energy is created or destroyed during the experiment. The principle of conservation of energy is also mentioned, stating that energy cannot be created or destroyed. Finally, it is clarified that energy is used to lift the ball onto the slide, but it is not 'created' in the process.
Fabian901
30
I'm going through a physics exercise at high school level. A ball is dropped through a slide and when it reaches the bottom of the slide it will travel horizontally. Assuming there is no energy loss due to friction or air resistance draw a velocity time graph.
I tried working it out, the answer on the book says that when the ball reaches the bottom of the slide it will start moving horizontally with a positive constant velocity. I'm a bit confused on the constant velocity part. When the ball is moving horizontally, it obviously has KE. And the fact that it has energy doesn't it mean that there is a force applied through a distance, and therefore it should accelerate?
Many thanks in advance!
The ball's total energy is constant through the entire experiment. A force is only required to gain energy. All this experiment does is convert potential energy to kinetic energy.
Likes Fabian901
Many thanks Russ! I don't think I understand the principle of conservation of energy that well then. Imagine that before someone put the ball on top of the slide the ball was standing on the floor with no motion, what was the energy of the ball standing still on the floor? Is it 0 joules? Was energy being created to place the ball on top of the slide? If so, wouldn't this contradict the principle of conservation energy which states that energy cannot be created or destroyed?
Measured with respect to the floor, the mechanical energy of the ball would be zero. (0 gravitational PE + 0 kinetic energy)
Energy was used to lift the ball and place it on the top of the slide, but that energy wasn't 'created'. For example, if a person lifted it, that person had to do work on the ball, essentially converting some biochemical energy to give the ball increased potential energy.
Not to worry. Conservation of energy is safe and sound!
Likes Fabian901
Thanks a lot for the help guys!
Related to Kinetic energy physics exercise
1. What is kinetic energy in physics?
Kinetic energy is the energy an object possesses due to its motion. It is a scalar quantity that depends on an object's mass and velocity.
2. How is kinetic energy calculated?
The formula for calculating kinetic energy is KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
3. What are some examples of kinetic energy?
Examples of kinetic energy include a moving car, a rolling ball, a swinging pendulum, and a flying airplane.
4. How does kinetic energy relate to potential energy?
Kinetic energy and potential energy are both forms of energy. Kinetic energy is the energy of motion, while potential energy is the energy an object has due to its position or state. They can be converted into each other in certain situations, such as a roller coaster going down a hill (potential energy to kinetic energy) or a bouncing ball (kinetic energy to potential energy).
5. How is kinetic energy important in everyday life?
Kinetic energy is important in everyday life as it is the energy that allows objects and systems to move and do work. It is essential in activities such as driving, sports, and even walking. Understanding kinetic energy can also help us predict and calculate the motion of objects in our surroundings.
  • Mechanics
  • Mechanics
